0 A Day in the Life...
0 remap. Y/N?
5 What color (s) were offered on a '65 CH ?
0 77 kicker engagement issues
Last Post: ccmman
0 Really Hard to start XL1200 C
0 SERIOUS 1275 engine issues!! PLEASE HELP!!
0 Front MC advise
Last Post: Randy_rots
0 Slowly finding Bits and Pieces ....
14 Iconic Parts that say it's a Harley!
Last Post: clif02
Last Post: PetesPonies
0 starter block off plate
0 ***DK Custom-Billet Handlebar Top Clamp w/ Indicator Lights Receptacle***
0 ***DK Custom-Finned Handlebar Clamps For Sportsters, Dynas, & Others***
0 Sale or Trade 2018 Sportster Mag wheels
Last Post: Whylee
5 Methods to quiet the old Sporty ?
0 Ohlins
Last Post: Jesus Jon
0 ***DK Custom-22LR LED Run-Brake-Turn Lights-Universal Fitment***
0 ***DK Custom-Stealth LED Saddlebag Run-Brake-Turn Lights***
0 stress killer
0 Gravydog crashed again.
Last Post: gravydog
0 Look at this
BH1218 (72), 1974iron (54), 2PSYCHO SPORTSTER (52), mhayek, sthomakos (42), Heian (26)
Old 15th September 2018
Dave L's Avatar
Dave L Dave L is offline
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Kawasaki Vulcan 700
Other Motorcycle Year: 1985
Dave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant future
Ha ha. Couple maxi pads on the starter. Doodah. I almost never put gaskets on dry. But I did these. I either coat em with oil or permatex.
Whitewalls's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: 1966 Honda Dream 160
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
I've never had luck with dry gaskets on any bike. I dampen gaskets with Permatex ultra black RTV. Not gobs or a mess oozing out when tightened.
Just lightly damp the entire gasket. Once tightened there is no evidence rtv was used. After 5k miles my Ironhead has not leaked a drop.
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Year: 1974
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
I like my old copper coat.
Murphy's Law :vvet:
Whitewalls's Avatar
I've used copper coat on car engines but I just don't like the look of the orange stuff showing on a motorcycle engine.
Subscribing Biker
I've used 3M Spray Adhesive a few times and had great results, If you spray it thin enough on both sides of the gasket.
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 96
Tim The Grim has a brilliant futureTim The Grim has a brilliant futureTim The Grim has a brilliant futureTim The Grim has a brilliant futureTim The Grim has a brilliant futureTim The Grim has a brilliant futureTim The Grim has a brilliant futureTim The Grim has a brilliant futureTim The Grim has a brilliant futureTim The Grim has a brilliant futureTim The Grim has a brilliant future
You take the standard black paper gasket, put it on a sheet of newspaper and generously rub black wheel bearing grease into both sides. I’ve always used Valvoline.
Let it sit while you clean and prep the other stuff so it has a chance to soak up the grease and then repeat the process again just before assembly, leaving a film of grease on both sides. The fresh grease helps maintain position as you fit the parts together.
Always progressively tighten the screws from the center points out so you don’t trap a bow in the middle. FSMs have torque specs for a reason. Use them.
The grease in the paper is multi-purpose. It moistens and lubes it so it becomes more malleable. It allows it to fit and flow into the minor surface imperfections that a dry gasket would miss. The heat cycling of the engine helps to create an almost impermeable barrier that will benefit from a second torque sequence after some heat cycles.
This is what I was taught 48 years ago when I bought my first HD and while I have occasionally had to double up on gaskets, (primary covers) I haven’t had to use sealers etc. Gaskets done this way are also easy to remove when disassembled.
'54 KHK, '76 XLCH (sold), '13 XL Seventy Two, '97 Honda Valkyrie
