0 New England 2018
Last Post: tvon
Last Post: rubine
0 WTF Happened
0 Cam timing and piston position
Last Post: spoon
0 WTB Rubbermount Air Shifter,Wheelie Bars
0 Metal Polishing
3 Thoughts on buying
Last Post: Sprtstr1200s
0 Let's See Them R's!!
0 Air quality went down the tubes
Last Post: Calcustom
Last Post: Bstrdbike
0 No Rear Brake Pressure
Last Post: Napawineguy
Last Post: DirtyCory
0 Brake shoe removal/installation tool
Last Post: Tyler Lillie
0 ***DK Custom-Limited Time 10% Savings on a Pair Of Quality Heim Joints***
0 THE Trainspotting Thread
0 seat bolt
Last Post: Bone
9 1973 XLH1000 stuck front brake caliper
0 Suzuki Lights On 883
0 Best value in a front spoke wheel
Last Post: Sportycus
0 ***DK Custom-Limited Time 10% Savings on ALL Handlebar Riser Extensions***
0 Happy Birthday norseXL!!!
Last Post: rubine
0 Progressive Fork Lowering Kit - New - $75 - San Diego
Last Post: OakBehringer
0 Who's still riding???
Last Post: Coolhands
0 Diagnostic bcm code
Last Post: Gaz907
0 Which forum for a Dyna Low Rider?
gp9739 (74), danbango (71), andyman1958 (60), 55 Jr (57), Love2FixIt (49), keywan (47), C Dubya (44), CA71xlch (43)
Old 10th October 2018
mmason mmason is offline
Sportster/Buell Year: 1984
mmason is an unknown quantity at this point
Default Frame mods
Picked up a 84 IH. Having a time finding aftermarket frame or an idea of how to add rake and some up and out. Plan on keeping the swing arm, and using a springer front end. As for now something in the 38-40 degree rake and 4 up and 2 out. all help app.
Old 15th October 2018
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant future
Find CLEAR photos of setups you like then post the best. It will be easy for others to tell you how they were done. Title passes with frame on your year so you might prefer to mod the stock frame for least hassle. There's plenty of info on the internet. Spend a few days learning how to find things in the chopper world. You'll be MUCH more capable than if you need spoon feeding.
If you aren't prepared to buy a quality springer, a springer may not be a brilliant idea.
IH rear suspension is sufficiently poor due to geometry you might consider a hardtail.
