0 Do people notice your bike?
5 '77 ironhead fork neck cup conversion internal steering stop
Last Post: Slytat
0 Spectro STL 75W140
Last Post: DéDé
0 2 into 1 exhaust build
5 Why Are You Still Married?
Last Post: oupa
0 How do you upshift?
0 Hoo rah for Missouri.
0 03 sportster front muffler Stud nut Thread size?
Last Post: gravydog
Last Post: ReddTigger
0 Cv carb jet question
0 900 dual carb front head
0 exhaust or cams?
Last Post: wrkdWS6
0 Oil Analysis?
Last Post: Bwf347
Last Post: oupa
Last Post: Four Speed
Last Post: spacecoast
Last Post: 83XLX
0 The Multi-tool thread
Last Post: gpydeski
0 S.Y.B. Next to a waterfall.....
Last Post: Lone Rider
0 new heads
Last Post: gpydeski
0 Runs rough on highway.
  #5751
Old 5 Hours Ago
boomerguy is an unknown quantity at this point
Originally Posted by Glamazon View Post
83XLX what's the seat likes for comfort? It looks harder than Chuck Norriss!
I'm curious, too. The seat looks hard and thin without rear support to keep you from sliding back. It is pretty, though. You really can't tell until you put a few miles on it with your own personal "bum". I think it would look really cool with coil springs but who knows how that would work...
My 2005 883XL Standard came with the original OEM solo seat, OEM two-up base seat and a Mustang two-up seat. I'm less than 5'7" tall and this is how they fit me:
OEM two-up seat was made to fit both tanks, 5.5 and 3.3 gallons which meant it was 2" farther back from my 3.3 gallon tank and was a challenge for my short reach to the handlebar.
Mustang two-up seat was specifically for my 3.3 gallon tank and snugged up to it perfectly but the base was flat and hard while the rear support felt like a board against my lower back.
OEM solo seat was specifically for my 3.3 gallon tank and is perfect in every way. I have a good reach to the handlebar, good cushion underneath that isn't too hard or too soft and still provides firm support which keeps me from sliding back. However, I can't say this will be the same for everybody.
Old 3 Hours Ago
Sportster/Buell Model: XLH883
hammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant future
Originally Posted by boomerguy View Post
I changed my fork suspension fluid. Even though it only has 10K miles on it, it is 14 years old. The stuff was solid black and stunk horribly. I locked the front wheel in place with a ratchet strap attached to the footpeg brackets and lifted the bike on my jack just enough to make it level and lighten the front end.
I removed the caps first to allow air in as the fluid drained and it all came out easily but it did take about 15 minutes for all the dripping to stop.
I replaced the OEM caps ("with a little help from my friends" holding down the springs) with the aftermarket ones from J&P Cycle with the inner fill cap so that I won't have to endure that agony again. This means I won't have to remove the caps or handlebar the next time.
Even though the owner's manual and "blue bible" say the capacity is 11.6 oz., only 10 oz drained and that is the amount I replaced.
It's supposed to rain tomorrow so I'll have to wait to see if there is any difference in the ride.
I doubt that you'll notice any difference. I don't believe the motor company puts drain plugs on the Sportster after ~'03. No tranny level plugs either. Now they want you to remove 6 screws and a cover to check the tranny level! As you did, I replace the amt. that I drain, and leave it at that.
Old 2 Hours Ago
83XLX's Avatar
83XLX 83XLX is online now
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Other Motorcycle Year: 1969
It's ok for about 30 minutes. It's not as hard as an old Badlander seat I have. It looks good, so for around town, it's fine. I also have one (and the matching p-pad) from '84-up and it's much more comfortable, but you lose the looks with it.
If I'm going on a ride that covers some serious distance, I use an OEM seat from an 883 Deluxe that I had some extra foam added to. It's pretty comfortable. Easy to switch out - just one screw to remove.
Old 25 Minutes Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
The only way to get it all out is to remove the legs individually and pour the oil out of the top. You can pump the forks in situ and this will help, but by the time you have removed the caliper/wheel and fender, it's only a few more bolts to drop the forks out.
There will be loads of old sludge still in there, but you can rinse the forks out with cleaner (paraffin/diesel), although you may have to do this several times before it comes out clean. If you decide to do it again this way, remember to slacken the top nut while the forks are clamped in the bike.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
83XLX
