12th August 2013
A Million Facts & Figures
Posts: 10,098 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
Supertrapp Supermegs Pipe Test - Mild 1250
The above is using 30 discs
The above is using 25 discs
The above is using 20 discs
This bike is a 2007 XL883 with the following mods:
Compression ratio is 10.5:1 and it's running on pump gas.
Comments:
As with the other recent tests, these are all 4th gear pulls.
Installation was straightforward, and it fit well, but man, that's some weird configuration for the oxygen sensors. I got'em on there, barely, but I really question whether you could actually run widebands on a street bike using this pipe. Pics to come, you'll see.
The pipe came with 20 discs. Mike included some extra discs so I was able to test all the way up to 30. With 30 discs, the screws were getting pretty short and there wasn't a whole lot of thread engagement, maybe 1/4". So I didn't feel comfortable going higher. I probably wouldn't even run 30 with the included screws on a street bike, but I figured it was OK for testing. If you get this pipe be sure to buy more discs and longer screws. Screws need to be stainless. Use generous amounts of anti-sieze every time you put it together (a small amount is included with the pipe).
Quietest pipe I've tested by a wide margin. Even at 30 discs, it's still a relatively quiet pipe.
Mapping took awhile because I was trying to keep the muffler from yellowing and that meant stopping and letting it cool at a lower temp than I normally would during tuning. I'm afraid I still got a little yellow creeping into the muffler. I've got a Supertrapp on my Dyna and it looks about the same, so expect it. The head pipes and collector got a lot of color into them, but of course, they're covered by heat shields in the normal case.
I did a total of about 170 pulls today between the Patriot and the 3 configurations of the Supertrapp. About 6 hours work altogether counting pipe swapping, mapping, and WOT pulls. I tried very, very hard to get every last .1hp out of each configuration, there it is.
You don't really see the top end changing much between the 3 disc counts, but you sure see it through the bottom and middle. Taking discs out makes it go more and more toward a dual torque peak shape, with a sag in the middle. Standby for a horsepower comparison chart.
12th August 2013
Posts: 2,275 Sportster/Buell Model: 883->HP1250 Sportster/Buell Year: 2006
these threads are like christmas
Always thinking 360°
12th August 2013
And of course, the comparison to the reference pipe ...
The Patriot remains undefeated on the top number. That's really remarkable considering all the good pipes we've put it up against. And it's not like it's bad down low or anything. Some pipes are a little stronger down low and/or through the middle, but not by a lot. The Patriot is just a really, really well designed pipe.
12th August 2013
Posts: 13,996 Sportster/Buell Model: XL1460C Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL1200R Sportster/Buell Year #2: 2006 Other Motorcycle Model: XL1200R Other Motorcycle Year: 2004
Aaron, was this with a closed end cap or open?
12th August 2013
Closed. You don't want to run an open end cap.
12th August 2013
I think I like Sportsters
Posts: 7,096 Sportster/Buell Model: 883L (sorta) & a 1200R Sportster/Buell Year: 2007 Sportster/Buell Model #2: 1200CX Sportster/Buell Year #2: 2016 Other Motorcycle Model: XR1200X Other Motorcycle Year: 2012
Good stuff Aaron! And thanks to Mike for loaning the pipe!
12th August 2013
OzChick
Posts: 3,406 Sportster/Buell Model: XL 1200N Sportster/Buell Year: 08 Other Motorcycle Model: Triumph Bobber Other Motorcycle Year: 2017
That's a real pretty torque curve with the 30 discs. It's very interesting to see how the discs change the shape low to mid-range.
Thanks again Aaron for your time in testing these pipes. And thanks Mike for sending and sharing your new pipe!
Does the mule ever get out in the fresh air to see the views of Idaho?
12th August 2013
It's kinda funny, we actually licensed the mule and got insurance for it, but it has yet to turn a wheel on the street since we owned it
Fortunately, we have other bikes!
12th August 2013
The other interesting thing about the torque curve ... look at the reversion way down low. You can really see it well in the 30 disc chart. Reducing the discs is making it go away. But reducing the discs is also causing a big hole in the middle.
I can't see going down to 20 and certainly wouldn't want to go less. Even though you're getting a little more at the very bottom, it's just killing the motor elsewhere.
It'd be interesting to see what it would do with more than 30 discs. My guess is, that real low end reversion would get worse, but it's so far down the rpm scale it doesn't really matter. I'm curious what it would do in the middle and on top. But 30 discs is already a real big block of stainless to be hanging off the back by those little screws. There's gotta be a limit to how many you can hang on it before something breaks off.
12th August 2013
Posts: 1,390 Sportster/Buell Model: Custom 88ci Sportster/Buell Year: Bits Other Motorcycle Model: '00
I second that.. Its really great to have this kinda information put out there for everyone to see.
