Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER & BUELL MOTORCYCLE RACING > LSR - Sporster & Buell Motorcycle Land Speed Record
LSR - Sporster & Buell Motorcycle Land Speed Record Discuss Sportster & Buell Motorcycle Land Speed Record events.
0 Arun Floods
0 Getting ready to try firing it up after a year long rebuid
Last Post: nychopper
Last Post: stikflote
0 my recent ebay purchase
14 Mid controls??
0 Intake manifold
0 Black Bike Bible
Last Post: 83XLX
0 Roadster CX Cafe Build
Last Post: Otter
Last Post: Carl74
0 CV40 spacing
Last Post: Carl74
0 Lucas fuel stabiliser
0 900 heads contd..
0 my only real beef with my 03 883
Last Post: robbie202
3 Wtb, Wts, Wtt, Wtg (Evos)
0 Harley-Davidson Sales Slump: What Next?
Last Post: brixtonanima
0 new to me 883
0 Dyno AFR and plugs on my 1275 04 Sporty
Last Post: Hellbent_4
0 Too HOT to ride?
0 Tank Paint Ideas
Last Post: MotorPete
0 Trans corner fix
cbsportster (69), sjeccles (52), 2011_Nightster (52), reeb (49), Maff (49), jl_rotary (42), UMLsilva (34)
Old 14th September 2014
Nytstr's Avatar
Nytstr Nytstr is offline
TurboMafia Charter Member
Sportster/Buell Model: XL1343NT LSR #1171/1175
Sportster/Buell Model #2: XL1250RT
Other Motorcycle Model: FXRP
Other Motorcycle Year: 1986
Nytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant futureNytstr has a brilliant future
Default Salt Rattler prepares for 2015 World of Speed
After a very successful rookie outing at the 2014 WOS, thoughts now turn to preparing for next year.
There will be some modifications to reduce drag. These may include modifying the ballast box because it sticks down below the crankcase, removing the instrument box and mounting the PV and AEM gauge directly to the upper triple tree, and sectioning the gas tank so I can get into a lower riding position.
Other possibilities include having the cases bored to accept larger cylinders so I can get to the 1350 class size limit, different exhaust cams and exhaust valves and gearing changes.
All that is needed is 11 mph to get the record!
Turbo Mafia Charter Member
Current LSR Record Holder: A-PBG 1650 134.594
RIP Sky Sanders
TGB #8
Support Your Local Land Speed Racer -
The Last Truly Amateur American Racing!
rubine rubine is offline
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
Hell yea Tom, Ill be following your progress and helping where I can.
rocketmangb's Avatar
So you build an 82 incher without a stroker ?
3.687 Bore ?
Gets 1334 CC ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 15th September 2014
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
3.700 bore. There's a ring pack available.
Click Here to Contact Me
Thanks Aaron
Im thinking normal numbers !
Sporty626 Sporty626 is offline
Other Motorcycle Year: 1987
Sporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura aboutSporty626 has a spectacular aura about
There is also the S&S 3 5/8 bore kit, 3.625 inch bore. You would leave some displacement on the table, but it's off the shelf parts.
But Why ?
3.625 Turbo piston is probably a custom piece anyway
I don't know how custom he wants to build it, just putting options out there. It would be one less custom part needed, apart from the pistons.
Nytstr's Avatar
Definitely going with the same custom turbo piston design that I'm running now, so Aaron is on top of it. Biggest deal is having the cases bored. I do need to pull the motor apart and see how the crank is doing, as it may need a teardown anyway. Ten runs at Bonnie could be tough on it, but really full boost was only happening on 2 runs.
Old 16th September 2014
Nytstr's Avatar
Actually I'm more concerned with what will happen in 2015. Now that I've figured out how to ride it I'll expect to be putting in hard pulls every time, so the abuse will be multiplied next outing.
