Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > Hammer Performance
0 Dyno AFR and plugs on my 1275 04 Sporty
0 Folkies Loft 2.0 " the Ccat tails "
Last Post: Yakcm2
0 Intake manifold
Last Post: oldboy
0 Anyone know where I can get one of these mini fairings?
0 Tool to remove giant screws
Last Post: SLW210
0 Tank Paint Ideas
Last Post: jsandidge
0 Harley-Davidson Sales Slump: What Next?
Last Post: Blowupster
0 FS Front brake line from '03 45121-96A*
Last Post: burely
0 Seized 1200SPORT Fork Cap
0 Screamin Eagle Wiring
Last Post: AntonieR
3 Shaky Dave Recovery
Last Post: Hornsmith
0 "S" model specific Q&A
0 900 heads contd..
Last Post: simonster123
0 Fuel tank urns
Last Post: ezmerf
0 wrong brake fluid
0 Trans corner fix
0 98 s10
Last Post: ezmerf
0 New to the Chopper Lyfe
Last Post: Bigshankhank
cobra0478 (76), Han (63), priell3 (59), Byrdman (55), jsta (53), YaeDio (52), chad.hart17 (47), doc (46), jfunk (46), lenainrouge (45), JohnDao (41), Razer883 (34), Slapchop68 (26)
Old 15th June 2017
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
Default 1.725 rockers and 660 cams
Has Hammer tested 1.725 rockers with the 660 cams and conical springs yet? I'm interested in upgrading from my 1.6 rockers and 1.98 intake and going to 1.725 and 2.01 intakes while keeping my 660 cams. Has this been tested yet? Can it be? Does the mule have that cam lift restriction of the later models? How about test on one of your old bikes like the wifey's Buell?
Old 15th June 2017
aswracing's Avatar
A Million Facts & Figures
Putting the 660's on stilts increases their already substantial TDC lifts, which reduces valve-to-valve clearance. You can sink the valves to get more clearance, within limits, but that makes the chamber bigger, and once you've got a full dome piston, making the chamber bigger mean a loss of compression.
So really you're talking about trade-offs between valve sizes and cam specs and compression. You can't have it all, you have to make choices. The trick is to find the combination that makes the most power.
Now you know why altering the valve angles is such a big deal. It lets you run more overlap and/or more valve, whichever you think will be more beneficial. But of course, you need enough bore size to support it.
Bottom line, to put the 660's on stilts you're going to be forcing yourself into smaller valves than would otherwise be possible. Will that make more power or less power than bigger valves on standard rockers?
Flow data can be useful in answering that question, as can well-understood relationships between optimal overlap for a given valve size to displacement ratio. But at the end of the day, it's cut and try that gives the final answer.
Click Here to Contact Me
Old 15th June 2017
rocketmangb's Avatar
That late model engine has trouble with the anti-rotators for the tappets and I think 600's are about it because of the base circle of the cams,lifter design and type of rotators.
Big valves and high lift are going to be a valve to valve clearance issue as well on any engine.
I think the 660 and 1.725 would give you .278 intake TDC lift and .266 exhaust lift.
Not to mention the possible geometry issues !
Your on dangerous ground here Mr. Spicoli !
Red Shift 643V2 might be an easier fit with Only .265 intake and .193 exhaust lift at TDC
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
