0 Replacement clutch discs
Last Post: ss396
0 2007 owners
Last Post: Bone
0 Shotgun Porn
Last Post: robbie202
Last Post: ReddTigger
0 Missing Man - SE Missouri Area
0 Lost compression?
Last Post: eddie XLX
0 Primary fluid escapeing into crancase
Last Post: Four Speed
0 Setting starter bendix end play.
0 THE Trainspotting Thread
0 Tires - Pros and Cons of Tubes vs Tubeless
Last Post: jp2code
Last Post: paulc
0 Greetings from central Illinois
Last Post: Veeflys
0 New To Harley
Last Post: Veeflys
0 Am I missing a front wheel spacer?
0 Good Day eh
Last Post: jharback
0 new (to me) '82 25th Anniversary Edition XLH 1000
Last Post: ezmerf
Last Post: ezmerf
0 33.4 fork axle help
Last Post: Bturkey
0 2013 72 TURBO For Sale
Last Post: Green hornet
0 High RPM cutting out HELP!
Last Post: Windtheropy
Last Post: Poison Pen
0 early 73 vs. late 73
0 Help: Weird electrical gremlin 08 Nightster
0 Issue that has me stumped
oakies, Gunhappy2 (60), SamIam (54), biggdann (48), boyer911 (48), danii (41), PVD24 (39)
Gold Member's Avatar
Sportster/Buell Year: 1972
Gold Member is a name known to allGold Member is a name known to allGold Member is a name known to allGold Member is a name known to allGold Member is a name known to allGold Member is a name known to allGold Member is a name known to allGold Member is a name known to allGold Member is a name known to allGold Member is a name known to allGold Member is a name known to all
Default how to pull oil pump
I *think* my oil pump may be bad. When I yank on it by hand, it won't come off easily. I've got it out by about 3/16". When I twist it a tad the gear that runs off the crank gear doesn't turn accordingly. It turns a little but not accordingly.
So I wonder if I need to pry it off and if that will be okay and not damage anything?
[/IMG]
shovithead's Avatar
shovithead shovithead is offline
Sportster/Buell Model: XLH XLCH
Sportster/Buell Year #2: 65
Other Motorcycle Model: XLCH
Other Motorcycle Year: 68
shovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of light
A total guess here. but the fit is not interference, but a tight fit. Even by hand, and no problems they can be hard to pull. but, it is probably all the shavings from the lunched tappet, in the bore, making it hard to pull. Try pushing it back up, cleaning with brake cleaner or some kind of cleaning fluid, blowing out with low air pressure and lubing it up with WD or PB and working it slowly out, and back in, over and over until it comes out. Even a little heat from a small torch may help, with expansion of the case. Do not try to pry on it, as you can do damage to both pump and case.
Keeping the Old Iron, on the road for another generation to ride.
mine was tight.i used a block of wood about 6- 8'' long and tapped on it,at the top of the timing gear with a ball peen hammer.it moved about a 1/4'' every time I hit it.
actually it was the roll pin that is through the gear that runs off the crank shaft...shoulda looked at the book but I have an old tailbone injury and a hemorrhoid calling my name today lol actually it hurts too bad to be funny.
the underside of the pump just comes off, I didn't see that
that just came up 3 weeks ago on another '72 http://xlforum.net/forums/showthread.php?t=2069778
