0 Replacement clutch discs
Last Post: ss396
0 2007 owners
Last Post: Bone
0 Shotgun Porn
Last Post: robbie202
Last Post: ReddTigger
0 Missing Man - SE Missouri Area
0 Lost compression?
Last Post: eddie XLX
0 Primary fluid escapeing into crancase
Last Post: Four Speed
0 Setting starter bendix end play.
0 THE Trainspotting Thread
0 Tires - Pros and Cons of Tubes vs Tubeless
Last Post: jp2code
Last Post: paulc
0 Greetings from central Illinois
Last Post: Veeflys
0 New To Harley
Last Post: Veeflys
0 Am I missing a front wheel spacer?
0 Good Day eh
Last Post: jharback
0 new (to me) '82 25th Anniversary Edition XLH 1000
Last Post: ezmerf
Last Post: ezmerf
0 33.4 fork axle help
Last Post: Bturkey
0 2013 72 TURBO For Sale
Last Post: Green hornet
0 High RPM cutting out HELP!
Last Post: Windtheropy
Last Post: Poison Pen
0 early 73 vs. late 73
0 Help: Weird electrical gremlin 08 Nightster
0 Issue that has me stumped
oakies, Gunhappy2 (60), SamIam (54), biggdann (48), boyer911 (48), danii (41), PVD24 (39)
  #521
I just remembered,it's possible your bike may have been under water after Katrina.
kaveebee's Avatar
kaveebee kaveebee is offline
Sportster/Buell Year: 1968
Other Motorcycle Model: kawasaki z1
Other Motorcycle Year: 1973
kaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant futurekaveebee has a brilliant future
Many people get it wrong?
Blowupster's Avatar
Blowupster Blowupster is offline
Sportster/Buell Model: Sporty XLH 883
Sportster/Buell Model #2: Sporty XLCH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: Jaguar XJ-6
Other Motorcycle Year: 1996
Blowupster is a splendid one to beholdBlowupster is a splendid one to beholdBlowupster is a splendid one to beholdBlowupster is a splendid one to beholdBlowupster is a splendid one to beholdBlowupster is a splendid one to beholdBlowupster is a splendid one to beholdBlowupster is a splendid one to beholdBlowupster is a splendid one to beholdBlowupster is a splendid one to beholdBlowupster is a splendid one to behold
WD40 is needed more often than for other bikes.
Well,
What I understand:
To reduce play it may be worth to screw the Bearing lock nut (the first on left of the picture) to reduce play of the first bearing, and to screw strong the Pivot bolt to reduce the the play of the other bearing.
Any idea of the torque needed to.
BTW what is the size of the bearings ?
Old 6 Days Ago
instructions for the bearing adjustment are in the f.s.m.they want you to use a spring scale on the swing arm to measure the resistance.
Old 4 Days Ago
Blowupster's Avatar
Thanks for info.
Will see how I will manage.
There are 2 screews: One is the bolt wich is 7/8 (23mm), the other is close to 36mm, I suppose it's a 1 7/16 or 1 1/2 inche.
The 23mm size does not existe in europe, excepte tool for car wheels, so it what I use. For 36mm I do not have so big tools in my ...kitchen. I will have to order.
Anyone can mesure if the size of the tool needed is 1 7/16 or 1 1/2 inch (for the Bearing lock nut) ?
Thanks in advance.
Next week i'm on holyday, I will be able to read on my phone but not to write as I lost y pasword and changed my email adress in january.
