0 Chinese S&S carbs
0 The last of a dying breed...
0 1979 Ironhead Starter Washer, Bushing
0 Carb starting issue.
0 WTB NOKK needle...
0 Tranny oil
0 Mikuni Knock Off "REVEALED" !!!
Last Post: davesz1r
0 Wont Fire up!
Last Post: Mission1
Last Post: farmerbill5
Last Post: FiftySixer
Last Post: davesz1r
0 Hot
0 Parts
Last Post: 1skullster1
0 Be Careful Out There!
0 XL 1200CX Wheels on 2020 883 iron
Last Post: Seanu30
0 XR mutt race bike progress
0 Coil polarity
Last Post: Model H
Last Post: bordens
boblaine (85), mike wels (74), GaryR (64), cat5752 (53), Ocbuckeye (50), commandesc (45), vividblack05 (38), north_cack
View Poll Results: Whats your ride?
1200 1,812 45.87%
883 1,584 40.10%
conversion 439 11.11%
other 115 2.91%
Voters: 3950. You may not vote on this poll
  #1081
Old 4th June 2020
rich56 rich56 is offline
Sportster/Buell Model: 07 1200xl custom
rich56 is a name known to allrich56 is a name known to allrich56 is a name known to allrich56 is a name known to allrich56 is a name known to allrich56 is a name known to allrich56 is a name known to allrich56 is a name known to allrich56 is a name known to allrich56 is a name known to allrich56 is a name known to all
Default ZCarfan! Well taken
The thing about not lugging the engine. I get it but have not seen this in the one Ironhead, one 07 Fuelie and current 06 Roadster. I have no problem with lugging or pinging with cruising at 2000 rpm or accelerating in the lower gears from 2k. Maybe because I havent had a need for more than 1/2 throttle for anything sane on my stage one carborated 1200. Or maybe only 93 octane
Except for buying cheap I see no reason to go 883 instead of 1200. Especially the weight is the same
Old 4th June 2020
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
To play devil's advocate:
* It's more fun to do things with less that others can't do with more
* Better fuel efficiency is fun.
* Gearing makes it a blast around town and on backroads.
* Yes it's cheaper initially and I'm the long run.
But you have to remember since we got rid of our Sporty ALL our bikes (but one) are 750cc or smaller. And really the ONE is ridiculous at twice+ any two of the others in both CC's and weight!
Old 4th June 2020
ZCarFan ZCarFan is offline
ZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant futureZCarFan has a brilliant future
I've had some of the questions about lugging as well since at tiny throttle openings there's not enough cylinder pressure to cause an issue. Yet, when I ask questions I get the dirty look so to speak then the pro-forma answer of "never ever"...
Mine is exceptionally smooth in 2nd or 3rd gear 1/8 throttle and 2400-ish
Agreed on the economics of the 883. Since everything is pretty much the same it really should only matter if either taxes or insurance is significantly higher on the bigger engine. In the USA, not so.
I really wanted a stock 1200S but unmodified ones are scarce now. I was looking for an unmodified 91-03 with a standard ride height, 19/16 wheel combo and a tach. Pretty much leaves the Sport and XLH. A 883 XLH, untouched except for a bafflectomy, showed up at a local dealer in great shape so I figured I could deal with the upgrade later. Probably should have waited for a Sport but it'll work out in the end.
So in my case I got the 883 because I had specific requirements for model and condition - displacement was lower on the list
Old 4th June 2020
Regarding the tailgaters speed target of N+1, the idiots around here even do it behind 18-wheelers when going uphill on steep 2-lane roads. All they can see is the back of the trailer and it doesn't even occur to them that the driver can't see them.
Also, there are lots of deer on the interstate around here and there are lots of cases of the front driver suddenly changing lanes to avoid one; then the second driver doesn't see the deer until it's too late. At interstate speeds, this is a fatal mistake.
Old 6th June 2020
60Gunner's Avatar
60Gunner 60Gunner is offline
Originally Posted by ZCarFan View Post
Me! That's what I gave up years ago. I had a 1200 Venture when I was 26 so I was over the hooligan stuff well before then. Was still taking my Impala to the dragstrips, but no more goofing off on the street. I cheated death a few times and got the message real clear.
Hell, I think I put too much weight forward for wheelies anyway. Even whacking the throttle open in 2nd gear on the Superduke GT I sampled at Barber didn't loft the front tire. Real nice bike though. Got better things to do with $20k however.
Oh, and shock of all shockers, I frequently go under the posted speed limit. A true rebel. Lol
It's not about the speed. Its how fast ya get there.
Sometimes I like to pull a steep hill a gear higher than usual and see how hard I can twist it and feel the torque.
https://live.staticflickr.com/65535/...c4672303_n.jpg
Bone's Avatar
Been a minute since there were Sportys in the shop.
So it was good that some friends came in with there's that were overdue for some service. It was a long afternoon but we knocked it out:
Fluids, Filters, Plugs, adjustments. Not too bad.
The his and her touring Iron and Uber-Low (a LOWERED Superlow, the rider is only 4'10") are ready to go.
Yeah the Uber-Low is so low we can't even get a drain pan under it unless we park it on blocks of wood. I'd use the lift for it and try to raise it with the lift jack, but it's hard to keep from high-centering it on the ramp and I'm not sure I could get the jack under it anyway.
Still it was nice wrenching on them again. I can't say I don't miss ours and I still flirt with a CX, I'm just not willing to part with anything else to do it, at least yet.
Similar Threads
883 or 1200 ????? collectovince Sportster Motorcycle General Discussion and Problems 28 5th January 2014 12:50
1200 conversion Frebirdchoppers Chopper & Bobber Talk 12 27th May 2005 15:51
883 to 1200 happyman Sportster Motorcycle Engine Conversions 55 15th April 2005 02:26
04 1200 cylinders/pistons for sale barry1967 Sportster Motorcycle General Discussion and Problems 27 8th January 2005 01:38
Selling my 04 1200 heads. barry1967 Sportster Motorcycle General Discussion and Problems 30 3rd January 2005 00:55
