0 Now I did it. Feel my pain
Last Post: motorfish
0 so it's officially ended
Last Post: Proteus
0 Oil not returning to tank
Last Post: poy6r
0 Xl???
0 Starter for an XLCH
Last Post: 72 Ironhead XLH
0 Xr750
Last Post: seajay
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Randy_rots
0 blocked main jet air bleed screw
Last Post: T_worth
0 Runs great - stalls on clutch pull
Last Post: tedcool
Last Post: rivethog
Last Post: FiftySixer
0 Help me identify this washer
Last Post: owlsplace
0 100 vs 110 front tire
0 Sportster drag bike
0 Curious question on E85
Last Post: Nicktater
0 no handlebar controls
Last Post: Samedward
0 Anyone tune for and use E85?
0 E85
Last Post: XL Dane
0 CV Carb hesitation
Last Post: ReddTigger
longrun-pa (70), goose59 (61), Stumble (56), Rowdy65 (55), peten (54), roderash (53), flightmedic (51), sportster steve (50), buscuit88 (32)
View Poll Results: What is your average Oil Temp when riding in the open road?
150 ish w/ out oil cooler 25 6.10%
150 ish w/oil cooler 14 3.41%
175 ish w/ out oil cooler 83 20.24%
175 ish w/oil cooler 15 3.66%
200 ish w/ out oil cooler 170 41.46%
200 ish w/oil cooler 20 4.88%
225+ w/ out oil cooler 25 6.10%
225+ w/oil cooler 0 0%
Not sure 29 7.07%
Who cares I just ride it 29 7.07%
Voters: 410. You may not vote on this poll
  #121
Old 29th April 2020
Highly-Dangerous's Avatar
I am looking for the one with black sphere & white numbering... all sold out in Spain... and no ones knows when will have more available!
Old 29th April 2020
Billy1200's Avatar
Billy1200 Billy1200 is offline
Sportster/Buell Model: XL1200 C
Other Motorcycle Model: Xvs650 dragstar
Billy1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to beholdBilly1200 is a splendid one to behold
I'v seen them on e bay uk only yesterday
2002 XL 1200C
Old 30th April 2020
Sportster/Buell Model: XLH883
Originally Posted by harley506d View Post
Genuine Harley analog type.
Bought genuine so i could sort of guarantee build quality and accuracy!
At least it comes off easy compared to stock and as long as you know how far off it reads, it matters not really.
Now that I've had mine for some years, I glance at it every-now-and-then.
Old 2nd May 2020
84cj's Avatar
84cj 84cj is offline
84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of
Recently put a Harley oil temp dipstick/gauge on mine. Bought a used oil tank for $10 that had a Harley gauge in it. Took it for a ride today, forgot to check the temp when I got home. A quick glance while at a stop light, appeared to be around 150. 67ish outdoor temp.
1999 1200S
Old 3rd May 2020
I went for a 120 mile ride today through the mountains and on the interstate. The ambient temperature went up to 80 degrees F. My oil temp went up to 220 degrees F and stayed there. I checked the oil when I got home and the level was the same. My 2005 XL883 Standard ran perfectly with the external crankcase breather. Tomorrow, I'm going to do it again and hope to get back home before the monsoons roll in for a few days.
Bike therapy. Gotta love it!
Old 7th June 2020
03SportyBoy 03SportyBoy is offline
03SportyBoy is an unknown quantity at this point
I know the engines are not the same but I learned you can lower or raise engine temps in the tuning alone.
Example: I used to have a 450 quad with a near nationals bulit engine. Talking 13:1 compression, single cylinder and water cooled. 180F was the target temp. A little rich it was a little lower, little lean it was higher.
I'm going to guess here with my 03 1200 my temps are atleast somewhat kept down due to pretty much perfect jetting along with the Dynatek 2ki ign module adjusted correctly. Mine only climbs over 200F on really hot days. But only maybe to 205F.
I strictly run VR1 dino. (50wt above 60F weather and 20w50 in cooler weather months). Call me a P.... But rides in 95F+ just suck. Helmet gets gross...best felt when you slip it back on after a decent hot ride....so I dont!
Thems my 3cents no one asked for��
Old 20th July 2020
Hellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud of
25 miles yesterday in 93 degrees. Not a lot of time at traffic lights and temp was around 190.
Old 20th July 2020
Monsoons are gone here and now we have temps in the upper 90's every day with very high humidity, placing the Heat Index well into the triple digits. If I can't ride in the early mornings, I don't go. I ride for pleasure, not pain.
