0 Now I did it. Feel my pain
Last Post: seajay
0 so it's officially ended
0 Starter for an XLCH
Last Post: 72 Ironhead XLH
0 Xr750
Last Post: seajay
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Randy_rots
0 blocked main jet air bleed screw
Last Post: T_worth
0 Runs great - stalls on clutch pull
Last Post: tedcool
Last Post: rivethog
Last Post: FiftySixer
0 Help me identify this washer
Last Post: owlsplace
0 100 vs 110 front tire
0 Sportster drag bike
0 Curious question on E85
Last Post: Nicktater
0 no handlebar controls
Last Post: Samedward
0 Anyone tune for and use E85?
0 E85
Last Post: XL Dane
0 CV Carb hesitation
Last Post: ReddTigger
0 Xl???
Last Post: SLW210
longrun-pa (70), goose59 (61), Stumble (56), Rowdy65 (55), peten (54), roderash (53), flightmedic (51), sportster steve (50), buscuit88 (32)
View Poll Results: What synthetic oil brand do you use in your cars or your bike. You choose more than 1
Amsoil 348 24.49%
Mobil1 545 38.35%
HD SYN3 294 20.69%
Royal purple 59 4.15%
Shell 16 1.13%
Castrol 84 5.91%
Penziol 14 0.99%
Other 223 15.69%
Multiple Choice Poll. Voters: 1421. You may not vote on this poll
  #501
Old 4th June 2020
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: Cyclone
Other Motorcycle Model: FXDC
I do run Spectro 6 speed synthetic in my Softail's tranny. A sportster specific primary oil, conventional, in the sporty tho because of the clutch.
Was kidding about the chainsaw oil, I used redline MTL in the FXDC primary before, just over the marketing. And anything that won't make the clutch slip is fine.
And always a synthetic gear oil in my FXDC gearcase. Have used redline pepto bismol, good cushion.
I've heard good things about spectro so next time I think I'll try it.
In the sporty primary/gearcase I put the bel ray sportster specific primary oil.
Neutral seems to find itself a little better than whatever the P.O. was using
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertramp 2/2
Old 13th July 2020
bordens bordens is offline
bordens is an unknown quantity at this point
Mobil1 or Amsoil if I find a good price.
Old 21st July 2020
glbsportster's Avatar
glbsportster glbsportster is offline
Sportster/Buell Model: 1200 C
glbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond repute
Mobil 1 is a Base 3 oil and Amsoil is at lease a Base 4 oil.....
Old 12th August 2020
davegeezzer davegeezzer is offline
Sportster/Buell Model: Buell Ulysses XB12X
davegeezzer is an unknown quantity at this point
A lot of Uly owners run synthetic; some don't. Some synthetic oil manufacturers claim their oils lower engine temperatures but I've never seen any objective data to confirm it.
Sounds strange, but as owner both of Uly and good ol' Silverado I'm not that enthusiastic about this hours long BikeWrenching and CarWrenching as I call it. I'm a big fan of HD Formula+ transmission oil. It's supposedly semi-synthetic. It's what the factory recommends, and it shifts noticeably smoother than 20W-50 engine oil in my experience.
Folkie Folkie is online now
Is it really? First time I've heard that.
Old 4 Days Ago
jp2code's Avatar
jp2code jp2code is offline
jp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to beholdjp2code is a splendid one to behold
Originally Posted by klown View Post
Synthetic is obviously better, so what brand does everybody use. I'm wondering what the most popular brand is. I have a suspicion that Amsoil is not very popular, just because you can't get it as easily as the others.
Walmart makes a synthetic V-Twin oil
Super Tech Full Synthetic 20W-50 V-Twin
As long as you replace your oil with clean oil, I'm good with it.
JoeP
Old 3 Days Ago
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Year: 2014
HD formula + is a mineral gear oil according to oil analysis over on bitog.com. Nothing special about it. Group II I believe.
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
