DaddyJay, cartoad2001 (74), Dirty Ernie (68), ncpickman (62), bri1200c (60), pquirk (57), GOTWA (54), gremlinsteve (54), lbowles2 (52), Guess (44), rnaway22es, blueandy88 (40), landon283 (35) |
14th August 2022
Rider Of The Iron Steed
Posts: 32,881 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
Originally Posted by doodah man
I also agree on the 35-65 ft/lb figure for the transmission output sprocket (rear drive) and 100-120 ft/lb on the engine sprocket - front drive inside the primary.
It is a common error, especially for newer members here and elsewhere, to confuse these two "sprocket" names. About a decade or so ago it was discussed thoroughly because I made the same error...
transmission output sprocket vs engine sprocket: very different parts
15th August 2022
Posts: 61 Sportster/Buell Model: Sportster 1000xlh Sportster/Buell Year: 1979 Other Motorcycle Model: 1975 cb750
Okay sorry.. left side (clutch hub nut and the sprocket to the left of it which I am calling the "compensating sprocket ", I was initially told 150-160. I put it on with an older "ingersoll rand " 1/2 inch. Drive pneumatic wrench. It's tight... somewhere between 120-150, I would say. That's (both) of the nuts in the primary case. The( right) side sprocket (the one that spins the chain (23 teeth) that spins the rear (wheel sprocket) 58 teeth, is the one I'm asking about.. the vote is 35-65 lbs., I guess?
15th August 2022
Okay sorry.. left side (clutch hub nut and the sprocket to the left of it which I am calling the "compensating sprocket ", I was initially told 150-160. I put it on with an older "ingersoll rand " 1/2 inch. Drive pneumatic wrench. It's tight... somewhere between 120-150, I would say. That's (both) of the nuts in the primary case. The( right) side sprocket (the one that spins the chain (23 teeth) that spins the rear (wheel sprocket) 58 teeth, is the one I'm asking about.. the vote is 35-65 lbs., I guess? By the way... thank you sooooo much!!! I would have probably done some damage. I hadn't remembered putting so much tourque on it before.. but I also didn't want a broke-loose chain tickling my leg on the highway! Again.. AND WITH ALL SENSARITY, THANK YOU GUYS. THAT VERY WELL COULD HAVE BEEN A LEG!
15th August 2022
Posts: 11,494 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
You’re welcome! Enjoy your legs lol!!
15th August 2022
Posts: 16,300 Sportster/Buell Model: XLCH stroker Sportster/Buell Year: 1960 Sportster/Buell Model #2: 883 C Sportster/Buell Year #2: '03
if you don't a a large obvious spring assembly on your motor sprocket shaft,you don't have a ''compensating sprocket''.yes or no?? the factory last used them in early '76.
72 1000cc barrels and XLR heads, S&S 4-1/2'' flywheels, sifton minus-minus cams, S&S super A w/ zippers thunderjet w/yost powertube, Andrews gears,and shafts, 72 oil pump, Morris magneto w/auto advance and single fire module, cycle electric generator w/electronic regulator,73 cu.in.
