Snippets
DaddyJay, cartoad2001 (74), Dirty Ernie (68), ncpickman (62), bri1200c (60), pquirk (57), GOTWA (54), gremlinsteve (54), lbowles2 (52), Guess (44), rnaway22es, blueandy88 (40), landon283 (35) |
12th August 2022
Posts: 61 Sportster/Buell Model: Sportster 1000xlh Sportster/Buell Year: 1979 Other Motorcycle Model: 1975 cb750
1979 1000xlh front drive (chain) sprocket tourque
That's all... I am just looking to see what the spec is on the front drive (chain) sprocket for my '79 1000 ironhead .My book shows nothing on subject!
13th August 2022
Posts: 503 Sportster/Buell Model: XLH1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 2004 XLH1200Custom Other Motorcycle Model: 2007 FXDB Other Motorcycle Year: 2004
My 1970 -1978 FSM gives it at 150 ft lb, same as clutch hub nut.
13th August 2022
Alright then, unless anyone out there in TV land has any conflicting answer, I suppose that, I too will be setting the tourque to 150 ft. Lbs. On my 1979 1000xlh. Thank you much Mr. 1Scooter!
13th August 2022
Posts: 6,032 Sportster/Buell Model: XLH Sportster/Buell Year: 72
You must be using the wrong book
13th August 2022
Upload came out fuzzy
The image of the tourque specs are coming out extremely distorted/"fuzzy". At least, on my phone... is it 100-120lbs.?
13th August 2022
Posts: 2,052 Sportster/Buell Model: xlh Sportster/Buell Year: 1974
You're looking for the nut torque on the front sprocket for the rear drive chain. Correct?
That spec is NOT on the page shown in post 4. It shows the sprocket shaft torque on the engine sprocket at 100 to 120 ft lbs.
The front sprocket nut torque on the rear chain (mainshaft nut) is in the manual.
35 to 65 ft lbs.
Sorry, I may be confused on what nut you're asking about. If you had said primary chain or rear drive chain it would be more clear.
13th August 2022
gear shaft 100-120
sprocket nut 100-120
crank pin 150-175cyl head 55-65
cyl base 25-35
These are FT/Lbs
13th August 2022
Posts: 2,216 Sportster/Buell Model: XLCH Sportster/Buell Year: 2003 Sportster/Buell Model #2: XL Sportster/Buell Year #2: 1981 Other Motorcycle Model: FXDC Other Motorcycle Year: 2013
I am no expert but will stick my oar in here
"sprocket nut 100-120" I'm taking this to be the front sprocket on the primary chain
The nut holding the front sprocket (countershaft) on my '81 driving the chain to the rear wheel sprocket is not very wide, I would not want to put 100/120 ft lbs onto it
I think 35/65 ft lbs is more in line with the hardware
Steve
bikes
13th August 2022
Agreed on all of the above.
Originally Posted by Steve9
..The nut holding the front sprocket (countershaft) on my '81 driving the chain to the rear wheel sprocket is not very wide, I would not want to put 100/120 ft lbs onto it
Neither would I.
It still isn't clear what nut we're talking about.
13th August 2022
Posts: 11,494 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
I also agree on the 35-65 ft/lb figure for the transmission output sprocket (rear drive) and 100-120 ft/lb on the engine sprocket - front drive inside the primary.
