0 With this fit my 99
Last Post: jordan1200
0 Happy Birthday wandrur!
Last Post: wandrur
Last Post: jcn59
0 1200s mid throttle stumble
Last Post: NZstu
0 New England 2018
Last Post: Boudwood
Last Post: tigger
Last Post: farmall
0 FS Stock 2012 Xl1200 and 1275 jugs
0 Reflectors...Yeah, or Neh
0 Folkie's Rural Rambles
0 Preston Candover
0 Tranny Question
0 Gravydog crashed again.
Last Post: gravydog
0 09 Buell XB12 crank
Last Post: Boudwood
Last Post: sltm1
0 2019 Suzuki Katana
Last Post: jammantoo
0 HAMMERING the Columbia!
Last Post: RKN
0 I have a problem with my sportster. (Intermittent Starting Problem)
Last Post: DYLAN
Old 11th July 2018
Danger_Jake Danger_Jake is offline
Sportster/Buell Year: 1973
Danger_Jake is an unknown quantity at this point
Default Bannana Caliper 73 XLCH- no brakes?!?
Okay so I've got a 73 XLCH with, what I believe is a one year only bannana caliper.
Old caliper needed to be rebuilt and the bleeder screw port was stripped so got a new caliper got it mounted and and was fighting to get it bled FOREVER, no matter what I did it felt like there was still air in the lines but after reverse bleeding it I'm pretty confident that there's no air left but I still have no brake.
Put a new line on it too, I know some times they swell and absorb the pressure from the master cylinder, still no brakes.
It's got some resistance on the lever but it goes all the way to the bars.
It seems like the puck isn't traveling as far as it needs to, I'm beyond frustrated I can't figure out how a single piston caliper 3 feet of line and a master cylinder have stumped me for a week.
Old 11th July 2018
well, back the pads back into the caliper and then shim with wood. try the brake, ok ??? if so, need new pads. hd does not have a brake pad wear indicator system, just a loss of stroke. next would be to observe the master when applying lever. is the fluid returning through the little hole?? if so, probably need a new cup.
Old 14th July 2018
Well it's a brand new caliper (and pads), new master cylinder and a new line. There is fluid returning through the small hole, I thought that was supposed to happen?!
Old 15th July 2018
in static position, the small hole towards the line going to the caliper is a common port that allows caliper fluid to return to the master. when you apply lever, the piston cup covers this hole and so it can build pressure in the caliper. in static form, this hole compensates for heat expansion. the larger hole is a return. when the piston drags backwards, the backup/seal o-ring causes a diff'l pressure that relaxes the chevron cup and the fluid will return to the master, notice the grooving on the metal piston part. if it wasn't for this, brake release would be longer since the small hole is a restriction and covered with the piston forward. when you first apply lever, you can see a brief spurt up the hole until the cup is pressure forced against the bore wall.
Old 17th July 2018
JacksBrother's Avatar
JacksBrother JacksBrother is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Davidson FLH
Other Motorcycle Year: 1973
JacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud of
I also have a 1973 FLH with the banana caliper. I recently had the same issue after rebuilding the front brake system. New braided line, freshly rebuilt master cylinder & caliper. Filled it with DOT5, pumped away, and the damned thing just refused to bleed-- no matter what. Finally decided there was a void in the dry master cylinder. Took the original hose and cut a few inches off the M/C end & screwed it into the cylinder with the chopped off hose pointed up using the flared elbow. I then drilled the center of the hose out to a little less than 1/4" and twisted a small clear funnel (from my reloading bench) into the open end of the hose. I filled it half full of fluid and slowly squeezed the brake lever. Big bubbles slowly rose in the funnel-- I repeated this until the bubbles stopped and the level in the funnel would rise when the lever was squeezed and lower when released. I hooked the brake line back up and bled the system easily. When trying to bleed a completely dry system, you can get "air locks" in the reservoirs of the M/C and caliper, you just gotta' work 'em out & get fluid back into the hydraulic cylinders at both ends. Hope this helps.
Good luck,
Joe
