0 Smaller turn signals
Last Post: lehel
0 My 900: half-H, half-CH
Last Post: RKN
Last Post: lehel
Last Post: Bow only
0 xied or x14ied?
Last Post: Joe_jeep
Last Post: ronccc
0 Speedometer hookup - 76 XLH
Last Post: Mission1
Last Post: Kbetts
0 Spark Plugs
0 Xlch spark plugs
0 Diagnostic code ?
0 Solenoid issue?
Last Post: Gulf Coaster
0 Resto-Repair 84 ironhead
Last Post: Hellbent_4
0 PSA on headlight shell wires
0 harbor freight lift
0 Digital odometer
Last Post: onadraw
10 The better than average BLUE bike thread!
0 Ceramic Wax
  #101
Old 5th July 2019
Penetrating oil and anti-sieze apparently doesn't work that well.
Corrosion X does. Everyone should have a can sitting around...
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Old 6th July 2019
Air-Cooled Forever
Thanks for the tip. I'll have to check it out.
Old 10th July 2019
I just did another clutch adjust after installing a ClutchLite release ramp.
The FSM procedure does suck. It is difficult to feel what's going on turning the screw if you haven't done this a lot and even then it's vague at best.
What is much easier is to grab the release arm where the cable attaches and check for movement there. Clearance (or lack of clearance) is obvious there as you adjust the screw. Check for release arm movement, same direction as the cable operating the release. You can easily feel the clearance (free play) change at the arm as you adjust the screw vs the vague feel you get at the screw.
Old 10th July 2019
Air-Cooled Forever
The first time I adjusted my clutch, I had burned my fingertips at work a few days before. That had made it easier to "feel" the screw touch. Now when I adjusted it, I had to check it 2-3 times and remembered it from memory. {Caution: Do NOT intentionally burn your fingers to make them more sensitive, it's just plain Stupid!} Live and Learn.
Old 28th July 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
I just did a readjust on my new E1. I use the method Tomcat mentions as I like to get it as tight as possible and back off no more than a 1/4 turn. Reason being is I also leave a lot more than 1/16" of play in the cable. More like 3/16". This makes for a short throw so it needs to start engaging pretty quickly.
Not for everyone and requires adjusting a little more frequently as everything needs to be just so.
Old 28th July 2019
rocketmangb's Avatar
The screw is not that tricky "IF" you have adjusted solid lifters
Counter clockwise until you just feel it "Kiss" then clockwise 1/4-3/8 turn
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
