0 Help me identify this bike
Last Post: AKL1
0 Speedometer hookup - 76 XLH
0 oil drive and gear timing
Last Post: volvocanadian
0 WTB: 40376-57 compensating sprocket extension
0 neat stuff, but didnt knopw where to put it
Last Post: ronccc
Last Post: Joe_jeep
0 xied or x14ied?
9 CV carburetor gurus...
Last Post: Dougray
0 Resto-Repair 84 ironhead
0 Why cafe a sportster?
Last Post: TUCCI
0 fp3
Last Post: 11alan111
0 Coronavirus & DK Custom Products - Update 3/18/20
0 15 sporty braided rear brake line
0 Mid West Meet & Greet
0 Digital odometer
0 Dual Disc Conversion - Slider Clearance
Last Post: shrimp
shotgun46 (62), Xtr2der (60), davidsdad (54), moondog (54), scout2006 (54), Kajun (49), Sam (45)
Old 22nd August 2016
BlackBikeDave's Avatar
BlackBikeDave BlackBikeDave is offline
BlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant future
no movement and no problems so far 500 miles on it. Would love to see what the spiral ring looks like as I am still in the dark about that.
Jerome 'Kid' Campo - 2/27/13 RIP "and I Ride like the Wind..To Be Free Again"
Old 8th February 2020
vagrant318's Avatar
vagrant318 vagrant318 is offline
vagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud of
I couldn't get the stock clip installed, mangled it. Am buying e clips now, pretty sure I couldn't fit a washer under it either.
Old 9th February 2020
c & e clips are dangerous as they can come off, cir-clip is a better solution.
the old iron piston pin retainers were spiral rings
think of a key ring, tight coil.
Bustert, any way you can post a photo or link to what you are talking about? I haven't had any problems since installing the OEM clip but I remember I was not too confident with how it installed.
Old 10th February 2020
vagrant318's Avatar
Interesting, I've heard others claim e clips are a much better solution than the stock clip? I'm still considering the Baker smooth shift kit but don't know what all is involved in the installation.
vagrant318's Avatar
Figured out I didn't have the plate aligned correctly when installing the stock clip, put on a couple e clips but it still seemed to have some movement. Might try a couple more methods with a washer but also have a couple more stock clips along with some other parts from Ronnie's coming so probably just use a stock clip again.
Old 11th February 2020
halfmt1 halfmt1 is offline
Sportster/Buell Model: XL 1200s
Sportster/Buell Model #2: XR 1200x
Sportster/Buell Year #2: 2011
halfmt1 has a brilliant futurehalfmt1 has a brilliant futurehalfmt1 has a brilliant futurehalfmt1 has a brilliant futurehalfmt1 has a brilliant futurehalfmt1 has a brilliant futurehalfmt1 has a brilliant futurehalfmt1 has a brilliant futurehalfmt1 has a brilliant futurehalfmt1 has a brilliant futurehalfmt1 has a brilliant future
The transmission needs to be removed for installation of the baker shift drum.
I went this route with mine, was not disappointed. The price would scare some away, but the star wheel is as secure as it can be.
Or you can modify the stock one which i should have done when i installed the sportgear.
what is bad about the cheesy hd retainer is it allows the plate to wobble which leads to the pawl pins walking out which now allows the plate to run off center and roller thrust usually forces the plate into the clutch.
https://res.cloudinary.com/engineeri...o/1_eaqlh3.jpg
spiral on top circlip bottom
vagrant318's Avatar
I was considering a circlip like that if heavy and sized correctly combo'd with a washer should work better than the Harley clip or e clips
