0 Help me identify this bike
Last Post: AKL1
0 Speedometer hookup - 76 XLH
0 oil drive and gear timing
Last Post: volvocanadian
Last Post: ronccc
Last Post: Joe_jeep
0 xied or x14ied?
9 CV carburetor gurus...
Last Post: Dougray
0 Resto-Repair 84 ironhead
0 Why cafe a sportster?
Last Post: TUCCI
0 fp3
Last Post: 11alan111
0 Digital odometer
Last Post: shrimp
  #161
Old 29th January 2020
Bryan1976's Avatar
Bryan1976 Bryan1976 is offline
Sportster/Buell Model: 1275 Sportster
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 1998
Bryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond repute
Originally Posted by neilp View Post
Great thread - any updates?
Not really I have the engine completed. I am currently working on painting my tins. I still need to install a new key switch. I’m looking for a barrel type switch that is compatible instead of the stock style. Also have to get a speedo mount with the dash lights. ( lost the old dash cluster in a move.) Here is a pic of my tins so far.
Blue collar knuckle buster. Some call me slow Stroh. The people I work with call me G.S.D.S. They say if you want it done right , you better send G.S.D.S
Old 3 Weeks Ago
Bryan1976's Avatar
Default My 1250 to 1275 build
Alright guys this is baking my noodle. I put the A/C on and the bottom of it is kicked out more than the top. Its really buggen my ocd. Now I didn't torque down the manifold until I got the carb out n place. Also removed what I needed to on the fins for carb to fit. Install the breather and Buell carb bracket. I thought the carb bracket was bent so I grabbed the other one I had and same thing. Kind of hard to see in the picture but here it is. Or am I just batt s#%t crazy?
Old 3 Weeks Ago
rocketmangb's Avatar
Not touching the fins for sure ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 3 Weeks Ago
Bryan1976's Avatar
Yes sir checked it and double checked it.
Old 3 Weeks Ago
Seems I have extra spacers between the heads and bracket
HRS48 and Hammer manifold
Old 3 Weeks Ago
Bryan1976's Avatar
Ah hathat's one thing I didn't think of . Just add a thicker washer. Did you seal them in any way so they don't leak ? Or dose the torque seal them up good. The way I have it set up is bolt ,washer,breather , washer , bracket , washer. So 3 washers pre side. Thanks rocket man. Some times I get so deep into things and over look the simple stuff.
Old 3 Weeks Ago
I have like a total of 5 nylon washers per bolt
Old 3 Weeks Ago
vagrant318's Avatar
vagrant318 vagrant318 is offline
vagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud ofvagrant318 has much to be proud of
I looked at mine, looks the same as yours, almost imperceptibly tilted. Same washer arrangement too, washers sandwiching the bracket with stock carb
Old 3 Weeks Ago
I just have a thick nylon between the head and bracket and one under the bolt
Old 3 Weeks Ago
Bryan1976's Avatar
I'm going to have to make some new breather bolts. I'm running the horse shoe breather. I can get the A/C mounted Straight but am running out of threads on the bolts. So this weekend I make up a set on the drill press . I don't want to block off the head breathers .
