0 Resto-Repair 84 ironhead
Last Post: Robyart
0 Who runs 70wt. oil
Last Post: 72 Ironhead XLH
0 One Year
0 2007 XL1200L Rocker Box Gasket Replacement-Moving the ignition wire harness
Last Post: rickie1031
0 FNG from Oregon
0 Bigger rear Pulley
0 Solenoid issue?
Last Post: BigMek
0 Don't drive angry
0 Rear Axle Nut Torque Spec.
Last Post: einheit 13
0 Smaller turn signals
Last Post: Joe_jeep
0 Help, Headlight out and fuse thing clicks?
Last Post: Racepres
Last Post: thecarnie
0 Marrying used speedometer
Last Post: Tiaan
0 Sportster cv carb tuning after upgrades.
0 1960 XLCH in the UK
Last Post: chilly
Last Post: Bone
0 Talk to me about Painting
0 Diagnostic code ?
0 Never seen this before...
paxman1, bkdyson (64), kd4tsc (64), Donson56 (64), BrnAgn, Sandman (57), AREA, The_Bishop (48), Delzore (48), dwrains (39), relykz (38)
Old 11th January 2020
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Quality sockets don't slip if you use the correct size. Glad you found something that you like.
Folkie
South East England Riders
stikflote stikflote is offline
Sportster/Buell Model: sportster xlc
Sportster/Buell Model #2: xlh 1200 c
Sportster/Buell Year #2: 2005
Other Motorcycle Model: Triumph Kawasaki
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
They are both good sets but i do prefer hexagon sockets i have had the Halfords set a good few years the lidl stye only about a year
rejeanprimeau's Avatar
People wrongfully use the 12 side box on six side bolt and complain to round the head???
Each tool for it proper use.
My first tools were in a box given to me by my dad over 55 years ago. He always said to never by cheap tools because you will never lose them and you will rarely break them. I still have that original box of tools plus many, many more. I've never bought cheap tools and I only lend them to someone I trust. When I finish a job, I put them back in their designated place. Dad also said, "A place for everything, everything in its place."
Just like shoes, in the long run expensive tools are less expensive than the cheap ones.
Folkie's Avatar
Brass Nut
I have no experience of Lidl tools whatsoever. With the Halfords tools, it is particularly the Professional range that I recommend. There are, of course, many other good quality ranges of tools. I have got several items from the Draper Professional range, particularly large sockets for rear axles, and such, where I couldn't easily find them in other makes. Snap-On are always good, and sometimes you can't find what you want anywhere else. There are many other quality makes, but mostly you can only find them online.
I have on occasion bought tools from the States, when I couldn't find what I wanted in the UK at all. Eg: lock ring pliers (not circlip pliers). And I wanted a deep, thin wall, 9/16" six point socket, for the stock breather bolts. In this case a six point socket is necessary, as there is very little engagement of the socket with the flats of the 'bolt', and in this case a 12 point socket is liable to slip. The only place I could find such a socket (in a reasonable quality) was from the US; so I did (Tekton).
I mentioned Halfords particularly, because almost everyone must have a Halfords branch not too far away, and it's easy to find out where the branches are. Anywhere else is going to be harder to find, and it's going to be different for different people.
