Last Post: ronccc
Last Post: 72 Ironhead XLH
Last Post: Joe_jeep
Last Post: Moon Wolf
0 xied or x14ied?
9 CV carburetor gurus...
Last Post: Dougray
0 Resto-Repair 84 ironhead
0 Why cafe a sportster?
Last Post: TUCCI
0 fp3
Last Post: 11alan111
0 Digital odometer
Last Post: shrimp
0 No spark
0 My 900: half-H, half-CH
Old 15th January 2020
npaisnel npaisnel is offline
Sportster/Buell Model: XL883 now 1200
Sportster/Buell Year #2: 1993
npaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant future
Yep, I bought it in 09 with 4000 miles. Due various issues it was out of use for about 3-4 years,
Other bikes, a car and truck, it does not get much use.
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
I'm not sure when I replaced mine, perhaps at 150,000 miles?
I currently have 263,000 miles on my 2006 Sportster and I know I am presently on the second one and have no thoughts on replacing it at this time.
I don't think it needs replacing, however if it will make you feel better go ahead as they are not that expensive
John Wayne - "The Shootist"
Does not sound like I need to bother ripping it down then
Thank you all
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Nothing wrong with having spares but I'd bet that in 5 yrs this one would still be sitting on a shelf. Just don't over-tighten the primary chain. The cases grow as they warm and the chain "tightens". A little "too loose" when cold is "just right" when up to temp.
Old 16th January 2020
OK, thanks
Old 7th February 2020
ferretface's Avatar
ferretface ferretface is online now
I changed mine when I did my trans gears upgrade. It was yellow-brown and was actually loose on the metal plate. The two screws were tight in the plate, but it still wobbled around. The new pad was only ~$6, so I put it in. I tightened the screws down, they felt like they were tight but I could still see ~1/32" space under the pad. And it was loose. I just kept tightening. Like an interference fit.
