0 FNG from Oregon
0 Who runs 70wt. oil
0 Resto-Repair 84 ironhead
Last Post: BigMek
0 Bigger rear Pulley
0 Solenoid issue?
Last Post: BigMek
0 One Year
0 Don't drive angry
0 Rear Axle Nut Torque Spec.
Last Post: einheit 13
0 Smaller turn signals
Last Post: Joe_jeep
0 2007 XL1200L Rocker Box Gasket Replacement-Moving the ignition wire harness
0 Help, Headlight out and fuse thing clicks?
Last Post: Racepres
Last Post: thecarnie
0 Marrying used speedometer
Last Post: Tiaan
0 Sportster cv carb tuning after upgrades.
0 1960 XLCH in the UK
Last Post: chilly
Last Post: Bone
0 Talk to me about Painting
0 Diagnostic code ?
0 Never seen this before...
paxman1, bkdyson (64), kd4tsc (64), Donson56 (64), BrnAgn, Sandman (57), AREA, The_Bishop (48), Delzore (48), dwrains (39), relykz (38)
Old 19th January 2020
stikflote stikflote is offline
Sportster/Buell Model: sportster xlc
Sportster/Buell Model #2: xlh 1200 c
Sportster/Buell Year #2: 2005
Other Motorcycle Model: Triumph Kawasaki
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
Default big bore kit
hi all, ive fou8nd a Harley tuner here in UK.
a 1275 bore Andrews cams and headwork
aropund £2000 ,whats your thoughts please
rocketmangb's Avatar
Doesnt sound too bad,
$2600.00 US
I would like to see the estimate,there is a lot of parts involved that get forgotten !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
TRY this, Fast Lane Head Work, UK
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Your 05 would need an aftermarket ignition module for instance. A big bore kit wouldnt last long running stock timing.
harley506d's Avatar
Sportster/Buell Model: 1200c
Fast Lane get good reviews and they always come across similar to Hammer for being helpful.
Always on here............http://www.harley-davidson-hangout.com/index.html
Yesive looked at them and they get good reviews
Im not sure yet of having it done ,because have to get bike to him
ITSall Anmd brokje in dyno jetted would think he would sort ig nation
,i would have to have a new clutch any way ,
just giving a lot of thought
60Gunner's Avatar
Chief of Security
"Headwork" is pretty vague.
Head work is gas flowed ported and bigger valves ,
no good putting stock valves ,with a bigger camshaft
Ive actually worked on a copup[le 650 Triumphs i used to own
the camshafts were quite famous E3134,ANDthey did make a difference used a bigger carb as well
npaisnel npaisnel is offline
Sportster/Buell Model: XL883 now 1200
Sportster/Buell Year #2: 1993
npaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant futurenpaisnel has a brilliant future
Alex (FastLane) did mine,
Came in about £2600 with clutch and N4 cams,bigger valves with standard springs,EnergyOne Clutch and Dyno’d
You will need an aftermarket ignition, plus the cooler spark plugs, for some reason Alex did not fit them. 2 grades cooler, same as XR1200.
California Phil’s does the Daytona Twin Tec TC88A ignition for $275 USD.
I am ordering stuff from him this month..
I’ve PM’d you. You’d save on postage etc if it got packed up with my stuff from him
Old 20th January 2020
For spark plugs the NGK DCPR8E or the Iridium DCPR8EIX will be perfect
