0 Help me identify this bike
Last Post: AKL1
0 Speedometer hookup - 76 XLH
0 oil drive and gear timing
Last Post: volvocanadian
Last Post: ronccc
Last Post: Joe_jeep
0 xied or x14ied?
9 CV carburetor gurus...
Last Post: Dougray
0 Resto-Repair 84 ironhead
0 Why cafe a sportster?
Last Post: TUCCI
0 fp3
Last Post: 11alan111
0 Digital odometer
Last Post: shrimp
Old 15th February 2020
Gone Gone is offline
Default wrong brake fluid
i bought bike from Harley only dealer asked salesman if it went threw the shop
he yep they checked it all out. well i noticed someone changed the front line to steel and notice a little bubble in the paint on cap i though to my self dot 5 shouldnt do that. so i figure someone used wrong fluid. well i was right
here is a link to the pics all flushed out to dot 5
Default grr link didnt work hopefully this does
https://ibb.co/album/fbQirF
Hippysmack's Avatar
Here's my DOT 5 after going too long without changing it.
Don't look much different from yours that I could tell from your pics.
Was it just gunk or was it jelly?
Mixing DOT 5 and any other should create jelly gunk/clumps.
After draining / before cleaning. No jelly but just ugly slime/trash.
c1skout's Avatar
c1skout c1skout is offline
Sportster/Buell Model: sportster 1200c
Other Motorcycle Model: Royal Enfield / BMW
c1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant future
Whether it had the wrong fluid or not, it's good that you changed it. That's a bit of maintenance that is TOO OFTEN skipped! I swap to new fluid every other year in my bikes.
i have run dot 5 with zero issues for decades. the system must be squeaky clean and rubber parts compatible. now if you have abs, need to stick to recommendations as the vis is a big factor. that said, not all abs systems are joined but most are since it is cheaper to make, some are independent.
yes it had small gel particles in it with some sludge at bottom you can see in pic with the new fluid i removed all the old brake fluid and cleaned the inside of master cylinder real good. lucky it cleaned up good and looks brand new inside.
yes your correct sir. german and itailan cars and bikes always say flush brake fluid every 2 years. i do it in all my vehicles and and atv's ect anything with hydraulic brakes. my dodge ram 2500 2006 has just over 300k miles and brakes feel new and never had brake issues can shine a light in reservoir and the fluid is nice and clear. cheap and easy to do overlooked maintenance as you said
Old 17th February 2020
TUCCI's Avatar
TUCCI TUCCI is offline
Sportster/Buell Year: 2016
TUCCI is an unknown quantity at this point
Every 2 years. What year is calling for DOT 5, my tech manual is calling for DOT 4 and mine is a 2016?
2016 ROADSTER
NLXL's Avatar
NLXL NLXL is offline
http://sportsterpedia.com/doku.php/t...ref:wheels03?s[]=dot&s[]=4
1959 to prior to Sept. 1976 production models DOT 3
Sept. 1976 to 2006: DOT 5
2007 and later : DOT 4
if you have the factory cap it should say on it what type of fluid to use
flushing the brake fluid will make your brakes work as intended and keep seals ect from leaking. dot 3,4 and 5.1 can mix but dot 5 is silicone and cannot mix with the others and you cant flush out all the dot 5 and use any other type as the seals are made for the silicone dot 4 should be flushed out at least every 2 years as 3,4,5.1 attract water and dirt out of the air more then dot 5
its cheap and easy so why not
