0 Smaller turn signals
Last Post: lehel
0 My 900: half-H, half-CH
Last Post: RKN
0 86-90 regulator-rectifier on 2003 engine?
Last Post: lehel
Last Post: Bow only
0 xied or x14ied?
Last Post: Joe_jeep
Last Post: ronccc
0 Speedometer hookup - 76 XLH
Last Post: Mission1
0 Intake seals, glad I checked them
0 Spark Plugs
0 Xlch spark plugs
0 Diagnostic code ?
0 Help with jacking up my sportster
0 Solenoid issue?
Last Post: Gulf Coaster
0 Resto-Repair 84 ironhead
0 Help, Headlight out and fuse thing clicks?
Last Post: Hellbent_4
0 PSA on headlight shell wires
0 harbor freight lift
0 Digital odometer
Last Post: onadraw
10 The better than average BLUE bike thread!
0 Ceramic Wax
mcevoy, Dnight (54), alvin01101 (54), rahean (52), 2005883c (46), cliff883 (45), HotRodSporty (44), Wes Marshall (41), liquidice148 (34)
Old 21st May 2010
LenC's Avatar
LenC LenC is offline
Sportster/Buell Model: NRHS 1250
Other Motorcycle Model: Triumph Bonneville Black
Other Motorcycle Year: '06
LenC has disabled reputation
Default Is it true? (eliminate clutch spring plate)
Read somewhere that the spring plate can be eliminated and replaced with 2 steels and a fiber....someone havin' the old man on or what?
Old 21st May 2010
shotgun46's Avatar
What ?
Old 21st May 2010
jh45's Avatar
jh45 jh45 is offline
Other Motorcycle Model: Electra Glide (sold)
Other Motorcycle Year: 2007
jh45 is an unknown quantity at this point
Talking about the spring plate in the clutch. Yeah there are kits out there to replace it with extra friction and steel plates. I don't have any first hand knowledge but I'm sure someone on the forum does.
Old 21st May 2010
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Yes some clutch kits come with the extra plates.
Old 21st May 2010
mozart577's Avatar
mozart577 mozart577 is offline
mozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nice
Yes, it is absolutely true. Many of us on the forum here have already done it and there are several threads and a sticky devoted to this upgrade. It was one of the smartest upgrades I've ever done on my bike. No more slipping. Clutch grabs right away, shifts smoother and finding neutral is effortless. Clutch adjustment is easier now and more accurate. I highly recommend doing it before the spring plate disintegrates; and eventually it will...
2005 883 Custom, 16" apes, Arlen Ness Big Sucker, w/EVO 8" round cover, National Cycle light bar, Mustang Wide Studded Solo Seat and Pillion, Khromewerks 2" drag pipe slip-ons, Cycle Visions 30" sissy bar, 3" tank lift, HB125XL Hydraulic Primary Chain Tensioner. Riding is my life. Blinging is just a hobby.
Old 21st May 2010
LenC's Avatar
Damn!
Completely missed the sticky and I just replaced the stock clutch assembly!
Is it possible to buy just the 3 replacement plates?
Old 21st May 2010
02883r's Avatar
02883r 02883r is offline
Sportster/Buell Model: 883r
02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all02883r is a name known to all
I agree, I went with the Barnett extra plate Kevlar clutch set. It wasn't overly expensive and was worth every penny!
Old 21st May 2010
XLXR's Avatar
XLXR XLXR is offline
http://xlforum.net/forums/s...d.php?t=168162
This is my thread with pictures when my clutch plate sheared the brass rivets at 17,000 miles. Actual wear on all the other plates was very very minimal. I replaced the spring plate with new, stock, from the dealer plates. You need two steel plates and one friction plate. I think I remember the number of plates correctly. I used all the other original plates.
Since then the transmission shifts like a Jap bike. Very smooth, very positive, clutch engages much quicker. It did take awhile to get used to it again. I suppose the clutch plate is simply there to prevent a newbie rider from dumping the clutch too fast and getting thrown off the back.
You must also adjust the clutch and primary chain correctly. I had to fill / drain the tranny and do a short ride in between about 10 times to get all the brass chips out. There is another clutch thread by CJBurr in the sticky section.
Old 21st May 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
Be advised the spring plate is there for a reason. It allows the best feel to the clutch.
I tried a Barnett extra plate kit and didn't like it at all because of the lack of feel. It grabs too abruptly.
It's true, the spring plates they do fail. I had one fail on my Road King in 60,000 miles, but in over 85,000 miles never had one fail in my Sportster.
The only thing a stock clutch needs to keep it from slipping is a HD spring.
Old 21st May 2010
XLXR's Avatar
Using stock plates avoids the grabby feel of high performance plates. Generally only bikes with Stage 2 or better engine mods ridden hard need high performance plates.
