0 2004 ICM
Last Post: tamaro
2 Your daily tunes...
Last Post: RDHenley
0 Exhaust pipes
Last Post: Joe_jeep
0 It's me - Kokopeli.
Last Post: Joe_jeep
Last Post: bill smith
0 Mid West Meet & Greet
Last Post: Bow only
0 Proper XLCH
Last Post: spamer80
Last Post: 1968xlch900
Last Post: MkC
Last Post: keithnh
Last Post: Bow only
0 Highway cruise speed
Last Post: xElvis
0 Front brake hose
0 2006 Sporty Charging System Upgrade
Last Post: RDHenley
0 Problem on a trip
0 Chinee Ignition
Last Post: RDHenley
0 900cc Pistons
Last Post: davixlrtt
0 Top End Whirring Sound
Last Post: Jason's Sporty
0 Simplified Wiring and Bars
Last Post: wannabehero
0 The farthest Ive ever trailered a motorcycle.
Last Post: RDHenley
0 TC88a help
Last Post: paulb
Old 26th August 2016
Sportster/Buell Year: 1991
Originally Posted by Sprtstr1200s View Post
$250.00 Ebay/Amazon. When the time comes for a battery... How long have you had it in your bike? Damn...10lbs. incredible .
I got mine for less than $200, just have to shop around. Coming up on two years now with absolutely no issues. It has sat for about a month and the battery responds as if it was ridden daily.
John
TStephen's Avatar
TStephen TStephen is offline
Sportster/Buell Model: XLH1200 Sporty
Other Motorcycle Model: Honda CB175
Other Motorcycle Year: 1972
TStephen is an unknown quantity at this point
Excellent advice John! This is the only real problem with the '93. It's an engineering defect and can be a real pain in the arse. On top of that it is a pain in the ass to replace the tank and costs a couple hundred bucks. But, the '93 is a great bike. I've had mine for well over ten years now and wouldn't trade it for anything. I've also been running a Shorai battery now for about seven years without any problems with either the battery or oil leaks.
Thanks for that info. I'll be taking a close look at mine during my upcoming winter tear down/rebuild.
To clarify you haven't had the same Shorai battery for seven years have you?
"Above all things avoid cowardice, for it makes men liars." ~ C.H. Spurgeon
Old 27th August 2016
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Yes, the same Shorai, although now that I think about it, that one is in the Guzzi. I've had the one in the Sportster now for about five years.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Originally Posted by buckeyejake View Post
One thing I do with all gas engines that have set for a while is give them a shot of Berrysmans B12 .
Every service I treat them with it too . I had a 91 , first year of the five speed ,get bike .
Jake
Or, buy a can of Seafoam, and run a couple tanks through the system. My carb was spotless inside after 25 years!
John
Old 29th August 2016
TStephen's Avatar
Thx for that great info.
MikeBel's Avatar
MikeBel MikeBel is offline
Other Motorcycle Model: Road King Classic
MikeBel is an unknown quantity at this point
Congrats on your new bike! Find a 10k service checklist and go through it on your bike. It'll also help you get acquainted with your new ride.
1999 1200S & 2012 Road King Classic
Hellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud of
2002 here and so far mines had rotting vac and fuel lines and leaking valve guide seals.
Lots of build-up on the tops of the valves. I should taken pics . . .
Other than that check your brake pads and a fork oil change might be in order.
MkC MkC is offline
Sportster/Buell Year: 1986
MkC is an unknown quantity at this point
10 pound savings with just a battery...I have check into that.
10 lbs is a huge savings! Do these have the same dimensions as the stock battery, as in will my stock battery hold-down and cover fit the same? Mine's an '86 and I'd love to be able to save my oil tank from damage.
