0 electrical
Last Post: rwilson8
0 Knocking noise in front cylinder!!!!
0 No start no click, helppp plz
Last Post: gotamotor
0 Need some help
0 '06 Sporster Oil Tank drain
0 Operation Live Wire
Last Post: Kbetts
0 Age limit where belts should be replaced?
Last Post: oupa
0 Old Parts
0 o-ring versus band intakes
0 Nothing much
Last Post: oupa
Last Post: Kbetts
0 Dual disks and caliper upgrade
Last Post: gwcrim
0 Hello from Germany
6 Hello from Central Vermont
5 Harley T-Shirts
0 Forum problems???
0 Piston size id?
Last Post: nychopper
0 Fuel Pump Problems
3 Ironhead Pictures Thread
Last Post: Island Dude
0 1979 XLH Carb
0 Hello from Murcia-SPAIN
0 Gibt es hier keine Deutschen?
Last Post: Clementine
stroker ace (79), beunme (59)
electrical, signal, sportster, turn, turn signal
Old 3rd August 2015
Little_Dave's Avatar
Little_Dave Little_Dave is offline
Sportster/Buell Model: 2003 heritage model
Other Motorcycle Model: MZ ETZ 250 cc
Other Motorcycle Year: 1986
Little_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura about
Thanks for the info guys, I took the tank off and parted the connector there, and there was a bit of corrosion on one or two of the pins. I cleaned them all up with a bit of fine wet and dry, a drop of wd40 and all is working ok!
Went out for a RBLRB charity ride-out yesterday and of course it was raining, but no problems whatsoever!
Old 4th August 2015
sportsterdoc's Avatar
Good!
Did you check the voltage after?
Old 4th August 2015
Didn't check it at all after as both front and rear indicators were glowing nice and bright with a good steady flash.
Old 4th August 2015
You may have resolved all the high resistance connections, but if the voltage at the socket is less than at the battery, then there may be other locations to clean up...before it gets worse. Could be the same situation with your tach
Old 6th August 2015
Thanks again for the further info: I'll check the live wire to the tacho against the battery voltage to see what it reads, these electrics are a bit of a dark art to me as can be seen from my posts!
Old 6th August 2015
Or the data wire (light green/violet)
