Last Post: Yakcm2
0 compression problems
Last Post: Sadsack
Last Post: MacSporty02
0 Nightster suspension upgrade (RK). Who has em?
Last Post: SportyHD
Last Post: Wilkinson949
5 how does you Sporty start?
Last Post: SportyHD
0 Bent rear (Pingel?) motor mount
Last Post: nakina
0 HD 100th Anniversary Sporty Pic Thread
0 900 dual carb front head
10 What's your Personal Tech
0 Hello From Cayman Islands
Last Post: heyshott 81
0 Project Strociek
Last Post: simonster123
5 Summer time heat
Last Post: Eric Von Zipper
0 Do you like Brazilians???
5 Do you feel you pay too much for Motorcycle Insurance?
0 Air Filter Soaks With Gas
Last Post: Beelzeboss
0 Big Bore '03 883R :)
Last Post: t120r
0 Replacing Stock Sealed Beam Headlight in my 1991
Last Post: Scuba10jdl
0 Newest "MYSTERY" problem - No life to my ride!
Last Post: Lone Rider
0 brake lines swap
Last Post: farmall
0 Introduction
Last Post: Veeflys
0 Electronics location 97 evo sporty
Last Post: Holytown
Last Post: Four Speed
Last Post: skypeace
Last Post: 2cvandy
0 Mid or forward controls.
0 Should I buy a Sportster??
electrical, signal, sportster, turn, turn signal
Old 3rd August 2015
Little_Dave's Avatar
Little_Dave Little_Dave is offline
Sportster/Buell Model: 2003 heritage model
Other Motorcycle Model: MZ ETZ 250 cc
Other Motorcycle Year: 1986
Little_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura about
Thanks for the info guys, I took the tank off and parted the connector there, and there was a bit of corrosion on one or two of the pins. I cleaned them all up with a bit of fine wet and dry, a drop of wd40 and all is working ok!
Went out for a RBLRB charity ride-out yesterday and of course it was raining, but no problems whatsoever!
Old 4th August 2015
sportsterdoc's Avatar
Good!
Did you check the voltage after?
Old 4th August 2015
Didn't check it at all after as both front and rear indicators were glowing nice and bright with a good steady flash.
Old 4th August 2015
You may have resolved all the high resistance connections, but if the voltage at the socket is less than at the battery, then there may be other locations to clean up...before it gets worse. Could be the same situation with your tach
Old 6th August 2015
Thanks again for the further info: I'll check the live wire to the tacho against the battery voltage to see what it reads, these electrics are a bit of a dark art to me as can be seen from my posts!
Old 6th August 2015
Or the data wire (light green/violet)
