0 Winter reading........
0 Stepped headers vs single diameter headers
0 Cafe or sport faing on xl1200cx?
Last Post: ORCX
Last Post: ZCarFan
0 Amputee Sporty Springer Trike Conversion
0 Trackday Sportster
0 A Separate Speedo and Tach
0 02 sensor query
0 How much should I offer for this 48
5 my 3D printed turn signals.. what would you print?
Last Post: hitchcme
0 Forum problems???
0 1998 Sportster Sport 1200s cam choice
Last Post: tattooglisha
5 Terminology Sticky?
0 compression problems
0 XB9 crank?
Last Post: Edster
Last Post: WI_duker
0 Hello from Murcia-SPAIN
Last Post: heyshott 81
fhilliard (78), paulmo (74), Beloved (48), Mr. Cro (48), Chopper Duke (40), Danny3nose (38)
ironhead, turn signal
Old 9th February 2016
JeepGuy61 JeepGuy61 is offline
Sportster/Buell Model: XLH Ironhead
JeepGuy61 is an unknown quantity at this point
Default Turn signal problems
I'm in need of some help. I just picked up a 1980 Ironhead this past weekend. Bike is in excellent shape but the turn signals do not work. At some point someone tried to rewire them and it's a mess. Is it better to just remove all the old wires and start new or is there a better way to fix without going that route.
Oldrump1 Oldrump1 is offline
Sportster/Buell Model: fxr xl1200 5sp
Sportster/Buell Year: 95
Oldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud ofOldrump1 has much to be proud of
HEY JEEPGUY,
Welcome. We have many threads called stickys, some of which address your problem.
Find what you need thru the google search box at bottom of the page. Also our forums are broke down by category and subjects. KNOCK YOURSELF OUT!
I don't wanna pickle, just wanna ride my motorsickle
Gene
Welcome to the XLforum...
You'll have to provide a better description of 'it's a mess' so that we can evaluate what was actually done (or attempted)...
Take a look at this thread:
http://xlforum.net/forums/s...hreadid=205077
__o~~o__
IXL2Relax
Thanks for the quick replies. By its a mess I mean none of the wires are the correct color s according to some research I've done and many of the wires are not connected to anywhere. Headlight and tail light work perfectly its only the turn signals from what I can tell. I read some forums on how to rewire them from scratch and just might go that route
jayel's Avatar
jayel jayel is offline
Sportster/Buell Model: xlh1100
Sportster/Buell Year: 1987
Other Motorcycle Model: Yam SR500
Other Motorcycle Year: 1978
jayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to behold
A keyed hot wire off the ACC. circuit goes to one contact side of the flasher, then from other contact of the flasher a wire splits into two wires one to each of one contact side of the turn switches, other contact of the switch splitting to front and rear turn lamp bulb, other side of the bulb frame grounds to complete circuit
PM sent
where are we going and why are we in this hand basket? 1987 1100 XLH
