0 Wet sumping?
Last Post: Four Speed
0 Thanks Hammer Performance!
Last Post: TX Dreamer
0 Breaking in a 17-year-old demo
Last Post: jcn59
0 Magneto mystery
Last Post: Serious Blac
0 Sad day ... Time to learn some more...
5 Are you married or single???
Last Post: jcn59
0 My First 100k Miles
0 what brake master cylinder can I use?
Last Post: Roane
0 Amputee Sporty Springer Trike Conversion
Last Post: MatHormell
0 happy or sad memorial day
0 Share your Sunrise OR Sunset Photos!
0 Brake upgrade
0 Carburetor 101 Float valve question
0 No name carbs.
Last Post: mickey t
0 answer with a question game
0 POTM (Pic Of The Month)
0 .551 Cams in an EFI 1200
Last Post: Akdawg
Last Post: XLPIZZA
0 Crane hi 4
0 a simple question on the grenade plate issue
0 frame links are kaput
Last Post: Will1250
0 Slip on muffler
Last Post: Nayra
headlight, ironhead, start, toggle, wiring
Old 8th February 2018
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Xl 883n
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Actually, your rocker gauge is a good show for flow. Lets you know the pump is working without opening the tank.
That said, it should peg out very shortly after start up and drop to near, but not at nothing, when fully warm. Maybe the gauge is defective as you have flow? Can't have uphill flow without a little pressure. I have one myself, on the rear rocker on the 70ch. Reads near 60 cold and 3-7 hot.
Ok, now I'm revived
brianbbs67's Avatar
I have been revived
Also, oil light should go out immediately(almost). If it is wired wrong or , in some cases(most) missing the diode, it will always stay on.
doodah man's Avatar
Good info here, I think...
http://xlforum.net/forums/s...d.php?t=191461
As to the oil flow, I think you didn’t run it long enough. You need to see it returning into the tank to be sure, just kill it if it starts to make any scary noises. Congrats on your 1st fire up, it’s always exciting to hear it roar to life for the 1st time and know that all your hard work has paid off!
doodah man's Avatar
I thought only the gen light circuit had the diode? I agree though, the oil light should go out pretty soon after start up.
brianbbs67's Avatar
I have been revived
You are correct. My bad.
... oil light should go out immediately(almost). If it is ... missing the diode, it will always stay on.
I thought only the gen light circuit had the diode?...
99484-85 Factory wire diagrams for 1979 to 1982 show both indicators are connected to the same orange wire after the diode. Changed for 1983-on.
doodah man's Avatar
Yes sir, but boodhah’s bike is a (modified) ‘72 model. I’m at work with no manual to check, but I’m pretty sure his would only have the diode attached to the gen light. Forgive me if I’m wrong!
In 99484-78 the first wire diagram to show the diode is 1978. I think the use of the diode corresponds with the move to the electronic/solid state/whatever it is called regulator. The mechanical regulator models do not need it.
You are forgiven
