Last Post: 45Brit
0 Reassemble engine
0 Repainted my bike
0 add oil and ride
0 The SPORTSTER car?
0 primary register screw
0 Halloween 1250 Conversion
0 One More Ohio Meet & Eat?
0 extra hole in neck web
0 Do you Run a Fuel Filter?
Last Post: FiftySixer
0 New EU rules?
0 '66 XLCH Running Pig Rich
0 Oil leak
0 'Sportster poster
0 XLFORUM quit smoking thread
Last Post: loki03xlh
0 stumble
0 Midget Harley?
Last Post: duffy
clean, metal, oil, oil pump, remove
Old 15th September 2020
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to behold
Originally Posted by seajay View Post
Not yet... but will check it out.
Thanks
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Originally Posted by Highly-Dangerous View Post
Excuse my ignorance but.... if you still have to tear it down, why going through the trouble of using magnets first? Why not tear it down first and then thoroughly clean all bits & pieces?
It is already tore down to cams removed and pinion gear and oil pump worm gear and oil pump removed.
Notice the bolt bosses down low inside the crankcase (ignore the arrows).
Debris can settle between the bosses.
No way to blow it out with the case halves together.
The wheel assembly is pressed into the right side?
The left comes apart with a light tap of a rubber mallet with the case bolts out.
Clean it up / out / blow all passages both ways with cases split.
Degrease case seams. Use 3 bond / Yamaha Bond etc. on the seam, bolts back in to spec per the service manual.
And now You know it's safe to put those expensive parts back on.
edit:
Remove that plug on bottom right as in the drawing in post 4.
That's a rifling hole to connect the oil scavenge passage from the sump to the pump.
You may find more there than just oil.
rocketmangb's Avatar
Im afraid I would split the cases
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Thanks read it.
