0 2007 LED Neutral etc display cluster/bar
0 Hello from Holland
Last Post: 45Brit
0 Reassemble engine
0 Repainted my bike
0 add oil and ride
0 The SPORTSTER car?
0 primary register screw
0 Halloween 1250 Conversion
0 One More Ohio Meet & Eat?
0 extra hole in neck web
0 Do you Run a Fuel Filter?
Last Post: FiftySixer
0 New EU rules?
0 '66 XLCH Running Pig Rich
0 Oil leak
0 'Sportster poster
0 XLFORUM quit smoking thread
Last Post: loki03xlh
Uberstorm Uberstorm is offline
Sportster/Buell Year: 1979
Sportster/Buell Model #2: ironhead
Sportster/Buell Year #2: 1979
Uberstorm is an unknown quantity at this point
Default Fat boy wheel
Putting a fatboy wheel on my 79 ironhead rear, can't find it now but someone advised to put the wheel on reverse and it fits fine, my question is, there markings on inner side around the core of the fathead wheel on one side , to be reverse what side should that marking be on a sportster.
Found the thread, from 2006, I'll leave it here if anyone else wants to contemplate it
http://xlforum.net/forums/showthread.php?t=20370
Bluto Bluto is offline
Other Motorcycle Year: 1973
Are you talking about the grooves around the bearing hub? Those indicate which bearing should be pressed in first and that part would not change when the wheel is reversed. They look like this...
Hi Bluto, thanks for the input. The fatboy wheel has numbers stamped on on side around the central hub, I was after using that for a guide on orientation
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Year #2: 2019
I think you need to go by bolt sizes, the Fatboy has the sprocket (7/16"-14 UNC) and rotor (3/8"-16 UNC) on opposite sides from the Sportster.
I wouldn't trust that they always put the numbers on the same side.
