Last Post: 45Brit
0 Reassemble engine
0 Repainted my bike
0 add oil and ride
0 The SPORTSTER car?
0 primary register screw
0 Halloween 1250 Conversion
0 One More Ohio Meet & Eat?
0 extra hole in neck web
0 Do you Run a Fuel Filter?
Last Post: FiftySixer
0 New EU rules?
0 '66 XLCH Running Pig Rich
0 Oil leak
0 'Sportster poster
0 XLFORUM quit smoking thread
Last Post: loki03xlh
0 stumble
0 Midget Harley?
Last Post: duffy
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Year #2: 2019
Theoretically yes, but in practice we know that the smaller ones round off too easily for some reason that doesn't quite agree with the logical physics.
In that article, note that the Allen wrench shown is too small for the bolt it is shown in. Done for effect I suppose, but neither the Torx or the Allen will work right if the wrong wrench is used.
Like stated, you are comparing quality to cheap. Cheap Hex are much worse the cheap Torx in apple to apple.
You need to by some quality stuff.
In practice, Torx is better if you know what your doing.
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Either buy the tools or change out the bolt.
Simple enough. Strength grade on seat bolt. XXXXXX please.
Traveled to
