0 2007 LED Neutral etc display cluster/bar
0 Hello from Holland
Last Post: 45Brit
0 Reassemble engine
0 Repainted my bike
0 add oil and ride
0 The SPORTSTER car?
0 primary register screw
0 Halloween 1250 Conversion
0 One More Ohio Meet & Eat?
0 extra hole in neck web
0 Do you Run a Fuel Filter?
Last Post: FiftySixer
0 New EU rules?
0 '66 XLCH Running Pig Rich
0 Oil leak
0 'Sportster poster
0 XLFORUM quit smoking thread
Last Post: loki03xlh
In the 2013 Sportster Service manual (99484-13) the battery specs are in chapter 6 Electrical under 6.2 specifications
Battery
12 V, 225 CCA, 12 Ah, sealed and maintenance free
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
