Last Post: heathkeenan
Last Post: ZCarFan
5 Harley T-Shirts
0 I was at the gym yesterday
0 Ok, talk slowly and use small words LED tail lights
0 Swingarm Bearing Preload Question
Last Post: rocketnorton
Last Post: XL1275
0 Ignition advice
0 Koso hd-01-04 2014+
0 900cc Cylinders
Last Post: Staffords
0 What’s your fuel injected 1275 idle speed?
0 Easy Brackets on 93 Sporty
0 Coil Resistance Question
0 Down on oil
0 Rear sets?
Last Post: bordens
0 Rear wheel alignment
Last Post: v3ko123
0 Sprortster Softail 1200 with Edelbrock NOS
Last Post: Randy_rots
0 Early Sportster Shock Absorber Disassembly
Last Post: soundnav
0 Anyone know normal operating temp?
0 CV carb running way rich!
8 Crankshaft Failure
air cleaner, arlen ness, exhaust pipe, exhaust system, rush exhaust
Old 28th July 2016
leodn leodn is offline
Sportster/Buell Model: Sportster Forty-Eight
Sportster/Buell Year: 2016
leodn is an unknown quantity at this point
Default New HD 48 - Slip on vs full system (With Screamin' EagleAir Cleaner Kit)
Hey guys,
I boght a new Sportster Forty Eight 2016. I already added a Screamin' Eagle Performance Air Cleaner Kit. Now I'm getting ready to pick some new exhaust and was set on v&h Short shots due to the look/sound and full exhaust system.
After some research it seems that short shots aren't the greatest for performance and that slip on's might also be a good way to go as far as performance gains. I like the idea of full systems but it seems the best is a 2-1 system and I just don't like the way those look plus they are $500+
Some of the systems and slip ons that got my attention are these:
Rush 3" Slip-On Mufflers
Vance & Hines Shortshots
Arlen Ness by MagnaFlow Lowdown
S&S Power Tune Sport Exhaust
What I'm looking for is:
1 - Look and Sound
2 - Performance
* Don't like 2 to 1 systems
* Price is not a big problem as long as it's under $600
Any advice would be awesome
Old 28th July 2016
Here are the links in case somebody dosen't know them:
Rush 3" Slip-On Mufflers - http://www.revzilla.com/motorcycle/r...15#reviews_tab
Vance & Hines Shortshots - http://www.revzilla.com/motorcycle/v...ster-2014-2016
Arlen Ness by MagnaFlow Lowdown - http://www.revzilla.com/motorcycle/a...ster-2004-2015
S&S Power Tune Sport Exhaust - http://www.revzilla.com/motorcycle/s...ster-2004-2016
Old 30th July 2016
xmikex xmikex is offline
Sportster/Buell Model: Iron
Sportster/Buell Year: 2014
xmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura aboutxmikex has a spectacular aura about
The rush slip ons are awesome and everyone seems to like them. I originally wanted short shots but after some research found out from a performance stand point they suck!! If you just want to be loud and have the same boring pipes as everyone else get the short shots. If not look into the rush SO also look t cycle shack SO and bassani SO.
If you want a nice 2-1 system though check out patriot defenders. One of if not the cheapest 2-1 system and performs well. Google hammer performance they have a whole section of just dyno sheets of a lot of popular exhausts. The rush SO are what I'm looking at and was one of the best performers. Don't go bigger then 2.00 baffles though after that on a stock bike people hVe had negative feedback.
Old 2nd August 2016
Thanks XMikex,
I did some more research and i think my new favorites are the "Bassani Pro-Street Exhaust System" but I'm not finding them for the 2016 forty-eight.
Do you guys know something about these 2 to 2 Bassani's? And is it possible to fit one 2013's exhaus in a 2016 bike?
