0 Forum problems???
0 Buell lightning
0 Suzuki's Radar Reflector Idea
0 2 into 1 exhaust build
Last Post: Trailhawk750
0 900 dual carb front head
0 Project Strociek
Last Post: Yakcm2
0 WTF Happened
Last Post: Yakcm2
Last Post: Steamboat_Willy
0 08 Nightster No Start
Last Post: jammantoo
Last Post: LLOYD883
Last Post: SportyHD
5 Do you feel you pay too much for Motorcycle Insurance?
Last Post: Eric Von Zipper
0 compression problems
Last Post: Eddie Lives On
0 wanted rim info
Last Post: curiousgeorge
Last Post: RAIDER0372
0 Air Filter Soaks With Gas
Last Post: Hopalong48
  #81
Old 27th June 2018
shanneba shanneba is offline
Default 5000 miles Red Line 20w-50 HD 5 micron filter
Here is my latest UOA from my 2013 Xl1200C.
30000 miles on the bike, 5000 miles on the oil.
Copper is still high.... I'm thinking rear valve guide.
I do see VEs on the rear cylinder that seem to vary at idle 3-5 %
I ran the 63731-99A HD Premium 5 micron filter this time to compare to the 63805-80A Standard HD and Mobil 1 M1MC-131 filter.
Scroll down in the code window to the particle counts.
First particle count is the HD 63805-80A Standard Sportster filter.
The second and third particle count is the Mobil1 M1MC-131.
The last one is the HD 63731-99A HD Premium 5 micron.
The 5 micron Premium filter did better at 4 and 6 microns than the Standard Sportster filter.
Not as good at 14, 21, 38 and 70 micron.
Maybe the 5 micron Premium filter isn't as "restrictive" as it seems
The next oil change will be using the WIX 57148 filter.
It is rated as 50% at 6 microns and 95% at 20 microns.
(the HD oil filter wrench, 94863-10, doesn't fit the WIX, the filter is 15 flutes and slightly ~2mm smaller diameter)
Code:
Miles on oil	4860	5000	5000	5000	5000
Total miles	10000	15000	20000	25000	30000
Date 	       06/15	02/16	10/16	08/17	06/18
Make up oil	0	0	0	0	0
Oil Brand	R L MC	R L MC	R L MC	R L MC	RL MC
Weight	    20w-50	20w-50	20w-50	20w-50	20w-50
Filter	        HD C	HD B	M1MC131	M1MC131	HD 5 mic
ALUMINUM	5	3	1	8	2
CHROMIUM	1	0	0	0	0
IRON     	12	8	5	6	4
COPPER	       263	132	75	72	84
LEAD	        6	4	1	1	2
TIN       	27	9	3	3	3
MOLYBDENUM	375	456	403	461	430
NICKEL	        1	1	0	0	0
MANGANESE	0	0	0	0	0
SILVER	        0	0	1	0	0
TITANIUM	0	0	0	0	0
POTASSIUM	11	7	4	1	3
BORON	        48	15	13	23	13
SILICON	        11	10	8	24	28
SODIUM	        11	7	10	7	7
CALCIUM	        2242	2703	2214	2528	2395
MAGNESIUM	156	45	16	12	10
PHOSPHORUS	1540	1676	1516	1703	1648
ZINC     	2046	2315	1811	2177	1980
BARIUM	          3	3	3	3	2
SUS @ 210F	96.2	98.8	103.9	99.1	97.1
cSt @ 100C	19.45	20.08	21.26	20.14	19.67
Flashpoint F	430	430	420	410	430
Fuel         %	<0.5	<0.5	<0.5	>0.5	>0.5
Antifreeze %	0	0	0	0	0
Water       %	0	0	0	0	0
Insolubles %	0.2	0.2	tr	0.2	0.1
TBN	        6.2
Particle Count
ISO Code (2)		21/14	18/14	20/15	20/17
NAS 1638 Class		12	10	12	12
ISO Code (3)		24/21/1424/18/1424/20/1524/20/17
SAE AS4059 cpc		12	12	12	12
4 Micron		122237	85538	99920	95886
6 Micron		18446	2430	8597	7971
14 Micron		97	117	269	1139
21 Micron		23	22	36	412
38 Micron		3	2	3	42
70 Micron		0	0	0	2
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 28th June 2018
Sportster/Buell Year: 1988
Again, very consistent results. Interesting that 20K onwards there is slightly more fuel in the oil, yet the flash point remains impressively high.
On the copper, do you have a bronze oil-pump drive gear installed?
Old 28th June 2018
Thanks for pointing that out!
ops, I rechecked my reports and both the 25 and 30K reports are actually also <0.5%. I changed the last post and updated my spreadsheet for next time
The engine is all stock, so it has what ever the stock gear is made out of.
For Alum and Iron I am getting less than half of the "universal averages" wear.
Old 28th June 2018
It's still an impressively high flashpoint after 5K!
Maybe the copper is coming off the cam or rocker bearings then? Perhaps an effect of the highly detergent ester oil base.
Old 28th June 2018
My 4100 mile run of HD SYN3 had a flash point of 460, it is likely a much better oil than many believe. ParrotHead has had many SYN3 UOAs with a flash point of 440-460 over his 200,000 miles.
I've seen other Red Line UOAs in HD engines with much lower copper wear.
Many of the early UOAs here in this thread also show higher copper values.
Old 28th June 2018
Interesting. Always good to have real data.
Old 30th June 2018
XLXR's Avatar
XLXR XLXR is offline
XLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond repute
The inconsistency of the number of specific micron sized particles over range of increasing mileage makes me wonder how accurate the tests are, or if that is just normal variation or if the different filters actually make some difference, and I question if knowing those different micron ratings have any real value. How can the number of smaller micron particles go down, but the number of larger sized particles go up in the far right column ?
Former Ricor test rider for IAS Shocks, Intiminators and Vibranators. Works Dual Rate fork springs, fork brace, Avon Venom X tires, loosen drive belt, and set frame rails level to floor. Read the "7 Pages of Suspension" thread in the Suspension Sticky Index to learn how to fix your suspension.
Old 1st July 2018
Sportster/Buell Year: 2018
Tucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura aboutTucsonmax1 has a spectacular aura about
You should try some of the Automotive options. I have a friend who runs a Purolator 10241. I ran a Bosch Premium 3330 on mine at 500 Miles. Then changed at 1k with the service(Used Bosch again). They're supposed to be rated for 20 Micron
Tucsonmax1 2018 Sportster 1200 Custom, 2016 Hyundai Tucson SE AWD
Old 8th November 2018
Here is the latest UOA from my stock engine at 35,000 miles.
Scroll down in the code window to see the particle counts.
I ran a WIX 57148 5 micron filter this time. It didn't do as well as the Standard Harley Sportster filter.
I am running another one for the next 5000 miles.
I may go back to the Mobil 1 filter next time.
Blackstone Comments:
Copper spiked up to 207 ppm this time, and tin increased with it, suggesting poor wear at a bronze
part. Interestingly, lead didn't even show up this time. Silicon is lower, so we're not sure that's to blame for
the dramatic increase in copper. It is possible that these metals are from something like oxides off the oil
cooler, but when that's the case, copper tends to improve after spiking, but it has been increasing instead.
We suggest checking back in ~3,000 miles to keep an eye on copper. The particle count was 24/22/16.
Code:
| Miles on oil    | 5000     | 5000     | 5000     | 5000     | 5000      |
| Total miles     | 15000    | 20000    | 25000    | 30000    | 35000     |
| Date            | 02/20/16 | 10/12/16 | 08/16/17 | 06/18/18 | 10/30/18  |
| Make up oil     | 0        | 0        | 0        | 0        | 0         |
| Oil Brand       | R L MC   | R L MC   | R L MC   | RL MC    | RL MC     |
| Weight          | 20w-50   | 20w-50   | 20w-50   | 20w-50   | 20w-50    |
| Filter          | HD B     | M1MC131  | M1MC131  | HD 5 mic | WIX 51748 |
| ALUMINUM        | 3        | 1        | 8        | 2        | 4         |
| CHROMIUM        | 0        | 0        | 0        | 0        | 0         |
| IRON            | 8        | 5        | 6        | 4        | 5         |
| COPPER          | 132      | 75       | 72       | 84       | 207       |
| LEAD            | 4        | 1        | 1        | 2        | 0         |
| TIN             | 9        | 3        | 3        | 3        | 8         |
| MOLYBDENUM      | 456      | 403      | 461      | 430      | 442       |
| NICKEL          | 1        | 0        | 0        | 0        | 0         |
| MANGANESE       | 0        | 0        | 0        | 0        | 0         |
| SILVER          | 0        | 1        | 0        | 0        | 0         |
| TITANIUM        | 0        | 0        | 0        | 0        | 1         |
| POTASSIUM       | 7        | 4        | 1        | 3        | 3         |
| BORON           | 15       | 13       | 23       | 13       | 16        |
| SILICON         | 10       | 8        | 24       | 28       | 19        |
| SODIUM          | 7        | 10       | 7        | 7        | 9         |
| CALCIUM         | 2703     | 2214     | 2528     | 2395     | 2433      |
| MAGNESIUM       | 45       | 16       | 12       | 10       | 10        |
| PHOSPHORUS      | 1676     | 1516     | 1703     | 1648     | 1691      |
| ZINC            | 2315     | 1811     | 2177     | 1980     | 1979      |
| BARIUM          | 3        | 3        | 3        | 2        | 1         |
| SUS @ 210F      | 98.8     | 103.9    | 99.1     | 97.1     | 99.9      |
| cSt @ 100C      | 20.08    | 21.26    | 20.14    | 19.67    | 20.34     |
| Flashpoint F    | 430      | 420      | 410      | 430      | 425       |
| Fuel         %  | <0.5     | <0.5     | <0.5     | <0.5     | <0.5      |
| Antifreeze %    | 0        | 0        | 0        | 0        | 0         |
| Water       %   | 0        | 0        | 0        | 0        | 0         |
| Insolubles %    | 0.2      | tr       | 0.2      | 0.1      | 0.3       |
| TBN             |          |          |          |          |           |
| Particle Count  |          |          |          |          |           |
| filter          | HD B     | M1MC131  | M1MC131  | HD 5 mic | WIX 51748 |
| ISO Code (2)    | 21/14    | 18/14    | 20/15    | 20/17    | 22/16     |
| NAS 1638 Class  | 12       | 10       | 12       | 12       | 12        |
| ISO Code (3)    | 24/21/14 | 24/18/14 | 24/20/15 | 24/20/17 | 24/22/16  |
| SAE AS4059 cpc  | 12       | 12       | 12       | 12       | 12        |
| 4 Micron        | 122237   | 85538    | 99920    | 95886    | 121960    |
| 6 Micron        | 18446    | 2430     | 8597     | 7971     | 25675     |
| 14 Micron       | 97       | 117      | 269      | 1139     | 485       |
| 21 Micron       | 23       | 22       | 36       | 412      | 96        |
| 38 Micron       | 3        | 2        | 3        | 42       | 14        |
| 70 Micron       | 0        | 0        | 0        | 2        | 3         |
| total particles | 140806   | 88109    | 108825   | 105452   | 148233    |
