Last Post: Brendenhrvy
Last Post: Ted Town
0 Spray on water resistance
0 supply and demand
0 Kehin carb spray nozzle
Last Post: Kingrabbit
Last Post: maltesefalcon
0 Which Brake Setup To Use?
0 Speedo cable hunt
0 Velocity Stack S&S Super E
Last Post: WhatsAnIronhead
Last Post: rocketnorton
0 Oil leak from engine bolt?
6 SPORTY BOBBER PICTURES
0 Ran out of gas.
Last Post: Dusz
Last Post: Dusz
0 Сar depreciation
Last Post: Fivecats
Last Post: bplinson
Last Post: bplinson
texrex (71), jjluvstoride (58), luisbmns (53), njstoehr (47), tacho75xlh (44), 80ironhead80 (34), Xttrackerr (28)
View Poll Results: How far CAN you go before you HAVE to refill your (carby) 3.3 gal tank?
Less than 90 miles 10 3.38%
90 - 94 miles 7 2.36%
95 - 99 miles 6 2.03%
100 - 104 miles 21 7.09%
105 - 109 miles 11 3.72%
110 - 114 miles 16 5.41%
115 - 119 miles 23 7.77%
120 - 124 miles 41 13.85%
125 - 129 miles 30 10.14%
130 - 134 miles 31 10.47%
135 - 139 miles 16 5.41%
140 - 144 miles 23 7.77%
145 - 149 miles 17 5.74%
150 miles + 44 14.86%
Voters: 296. You may not vote on this poll
  #91
Old 11th July 2020
Originally Posted by Counter Steer View Post
My '95 883 is the first sporty I've owned with the big 3.3 tank. I switch to reserve about 135, but I ride a lot easier than I did in my youth. I'm getting between 50-55 mpg and add about 2-1/2 gallons. My bike has wild turkey stage one and pipes with larger jets. Oh, I meant to say Screaming Eagle, wild turkey is in the glass next to me.
I really like this larger tank now, but I always loved the 2.1 or 2.5 looks. Every sporty I ever owned had the peanut, until now. So the extra gallon, I'm old enough to appreciate.
Looking at it another way, I always appreciated a gas tank that was larger than my bladder. At least, road miles wise.
When you switch the petcock to reserve at 135 miles, is it because you want to, or you need to?
I have the 3.3 gallon tank and I automatically start looking for a gas station after I pass the 100 mile mark on my trip meter. I've never had to switch to reserve because I would actually like to know if I'm in the "reserve portion" of my tank.
Old 11th July 2020
smilinbrad smilinbrad is offline
Other Motorcycle Model: Honda Shadow ACE
Other Motorcycle Year: 1996
smilinbrad has much to be proud ofsmilinbrad has much to be proud ofsmilinbrad has much to be proud ofsmilinbrad has much to be proud ofsmilinbrad has much to be proud ofsmilinbrad has much to be proud ofsmilinbrad has much to be proud ofsmilinbrad has much to be proud ofsmilinbrad has much to be proud ofsmilinbrad has much to be proud ofsmilinbrad has much to be proud of
1999 XL883C. I roll around 175 miles until reserve. Generally ad 3 gals at fill up. Normal miles per gallon about 60 mpg. Flat farm land, 45 to 50 mph easy rolling thru the forests and fields. One old, 170 lb grandpa.
Old 21st September 2020
bklyngeezer's Avatar
bklyngeezer bklyngeezer is offline
Other Motorcycle Model: Honda XL250R
Other Motorcycle Year: 1987
bklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond reputebklyngeezer has a reputation beyond repute
I average 45 MPG unless I get stuck in nasty traffic.
Miles per tank is different for me because I lifted my tank so high in the front, can't get as much gas in.
Usually hit reserve between 85 and 100 miles depending on traffic, temperature and general willingness to "get on it"
After that I make a bee line for a gas station, have yet to run dry.
I've pushed it to 130 miles, no further.
Maybe one day I'll fill a fuel bottle and see how far I can push it
2003 XLH 883H
2008 Honda CRF230L
1984 Honda XL350R
1987 Honda XL250R
"Only the dead know Brooklyn"- Thomas Wolfe
http://backwoodsrambling.blogspot.com
Old 15th September 2021
wedge's Avatar
wedge wedge is offline
My 05 Roadster needs to go to reserve anywhere between 85 miles and 100 like Bklyngeezer said in the above post. That depends on weather I am riding it constantly from fill to reserve or if it sits a few days here and there before reserve while I ride the 05 Custom. I think I have gone to 130 on reserve before finding a station, but not sure exactly what the furthest may have been. Once I hit reserve I head straight for gas or I will forget and end up stranded.
Old 6th December 2022
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
My '81 goes on reserve about 80 miles-2.5 gallon tank
Steve
bikes
Old 27th March 2023
My 2000, with the stroker motor, consistently gets 50-55 m.p.g. so 150 miles is not uncommon.
Riverrat1953 Riverrat1953 is offline
Sportster/Buell Model: Sportster 1200 Custom
Riverrat1953 is an unknown quantity at this point
Default Gas mileage
I always gas up at 100 miles, and all it takes is 2 gallons. But I have to mention that I am 70 years old and I ride conservatively.
