0 MS rollers way too tight
0 82 XLH struggling for power
0 -65A mufflers
Last Post: a-sad-anorak
Last Post: leon bee
Last Post: murphdog
0 Tools
0 Zippers 1250 kit
Last Post: wardie
0 my daily driver
0 Newbie
Last Post: BitterOldMan
0 OEM Headlight Bucket?
Last Post: spoon
0 KBS tank sealer
Last Post: mrmom9r
0 100 vs 110 front tire
0 mainshaft rollers size
Last Post: PappaBravo
Last Post: jcro61
0 my sunday driver...
0 carbs?
Old 6 Days Ago
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Default XL/XR mutt video and Barnett clutch adjustment
Hello all - I have a Barnett Scorpion clutch in the 1981 bottom end of my XL/XR mutt. I can't get it adjusted so it will completely disengage. I've tried adjustment at the clutch hub through the primary cover and adjustment where the cable enters the cover. I've had it adjusted so there is just a tiny bit of travel at the lever just to see if I get get it to fully disengage. I had it adjusted with the engine off so it will to roll in gear but now that it's running it won't disengage to allow me to stop in gear. There must be a technique that I'm missing.
Here's a video of it running. I fired it up yesterday - the first time I've had it running on both cylinders. It sounds rough as I haven't had time to sort the twin Mikunis out.
https://www.youtube.com/watch?v=NBGJZoIqW8I
Thanks for any advice.
Old 6 Days Ago
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
The 1981 and later IronHeads have a different clutch and a different adjustment procedure than the earlier models. I think that no adjustment is possible where the cable enters the cover.
Do you have the FSM 99484-85? It has the correct procedure.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 6 Days Ago
Thanks Mick. The FSM, now in front of me, in front of me would have been a good place to start. 1979 through early '84 uses the adjusting sleeve just to get rid of cable slack. I had been using it in conjunction with the adjusting screw to try to try and get proper adjustment. Thanks for pointing me to where I should have started.
Old 6 Days Ago
I think that is Late84 up has a different clutch release....
Causes for clutch drag,
- bad cable (lube or replace)
- damaged clutch disc(s)
- crushed or missing sleeves
- non-oem spring(s)
- fat grips or covers on the levers (decreasing lever travel)
- over-filled trans oil or wrong oil
#1 cause for clutch issues is poor adjustment
The push rod adjustment adjusts the clutch to the release mechanism.
The cable adjustment sets the lever free play.
Old 5 Days Ago
Ferrous Head's Avatar
Ferrous Head Ferrous Head is online now
Blind Owl
Sportster/Buell Year #2: 1966
What an UGLY Bike !
You need to get rid of that ASAP.
I'll see if I can find you a buyer.
Ok - found one.
