Last Post: Jaime1840
Last Post: LenC
0 81 parts
Last Post: Nickb2787
Last Post: BTD
Last Post: maltesefalcon
0 Secondery Vin tag
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 Cam question
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Last Post: dodgetrucken
Last Post: oldboy
0 Bike Beast
0 Old new guy
Last Post: ericfreeman
0 strange noise in top end
0 Oil leak
Last Post: Roane
Last Post: felis
0 BSA to be reborn...
Old 10th May 2011
IronheadMatt IronheadMatt is offline
Sportster/Buell Model: 79xlh
IronheadMatt is an unknown quantity at this point
Default vrod battery in ironheads
V rod battery in Ironheads anybody running them if so how do u like em? pros cons?
Old 10th May 2011
johnnyjellybean's Avatar
johnnyjellybean johnnyjellybean is offline
johnnyjellybean is on a distinguished roadjohnnyjellybean is on a distinguished roadjohnnyjellybean is on a distinguished roadjohnnyjellybean is on a distinguished road
I do. As long as your charging system is up to par, it's a good way to shed 11 lbs. You just need to make spacers to make it work in the stock XLH box. It also leaves room for tools is you want.
2007 96" Twin Cam FXDB 87HP 96TQ
Old 10th May 2011
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
Here's mine with my tool bag, i just have a cut off 7/16" spanner on my keyring should i ever need to get in there
24 beers in a carton. ...24 hours in a day . .. coincidence??
Old 10th May 2011
tat2d2dope's Avatar
tat2d2dope tat2d2dope is offline
Other Motorcycle Model: Shovelhead
Other Motorcycle Year: 1976
tat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura abouttat2d2dope has a spectacular aura about
i put a batt for a FXE shovel in my wifes 72 it's about V-rod batt size
i welded in some tabs. and welded in brackets to hold circut breakers in there also.
1973 iron head sportster fully customized the stock frame
SOLD for 76 shovelhead and $5000
Old 10th May 2011
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
I use a battery that fits my '07 Softail Deluxe and just cut some styrofoam to make it fit in the battery box.
Old 10th May 2011
Ivan RoachCoach's Avatar
Banned
Default I'm a HUGE fan of them...
...They're lighter, more powerful (no matter what the CCA & amp hours numbers say), and a breeze to live with --- no acid corrosion or fluid check bullshit.
I welded up a skeletal battery carrier for my own application, but yeah, the extra space is great for tools & is also a good place to stash your weed.
Old 10th May 2011
hcrashster's Avatar
hcrashster hcrashster is offline
Sportster/Buell Model: XLH Spinegrinder
Sportster/Buell Model #2: XLCH Frankenstien
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Triumph Groanyville
Other Motorcycle Year: 1972
hcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud of
With the roach on this one. Been using them for 3 years now. If you get the AGM style and ride regularly you can throw away the trickle charger. Very low discharge, longer life span, less strain on the generator, less weight. Except for 1 miss-step, [JP Cycles house brand], I've had no issues. Highly recommend Inter State's Cycle -Tron 2 series. Seems to be the best bang for the buck.
Old 10th May 2011
Banned
Default While I use the H-D brand, I recognize...
...that Deka is their supplier and you can save some $erious coin if you deal with one of their distributors.
- SPORTSTER -
Kicking Big Twins Squarely in the NUTS since 1957
CTFS/QCB
Viva Los Bastardos!!!
Old 10th May 2011
mikethebike61's Avatar
Just bite the bullitt and buy an Odessy.
Old 11th May 2011
Hard to beat this.............
http://cgi.ebay.com/ebaymotors/YTX14...Q5fAccessories
