0 Cam question
0 Secondery Vin tag
Last Post: Jaime1840
Last Post: LenC
0 81 parts
Last Post: Nickb2787
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Last Post: dodgetrucken
Last Post: oldboy
0 Bike Beast
0 Old new guy
Last Post: ericfreeman
0 strange noise in top end
0 Oil leak
Last Post: Roane
Last Post: felis
0 BSA to be reborn...
Old 14th October 2016
paulc paulc is offline
Sportster/Buell Year: 1976
Sportster/Buell Year #2: 74/5
paulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond repute
Default Upside Down Monoshock IH - A Longterm Project
Been itching for a new project for a while. Came up with the idea of taking what I did to my 76 a little further this time - an IH with upside down forks and monoshock suspension.
Very early days but thought I'd start a build thread now though right at the outset just for fun. Here's the story so far.
Last winter I picked up a messy old GSXR400 Suzuki
Pulled it apart and sold most of it off, leaving me with this for very little outlay:
The wheels won't stay that colour! Sold off the monoshock as well as no way will that fit in an IH.
Recently bought another IH - a 75 engine and 74 rolling chassis hybrid. Bought it from my Indie, after pestering him for a long time Engine just rebuilt throughout, new Andrews transmission The rest is a bit of a mess but mostly there:
Got it home today, now the planning and money saving starts in earnest. Hope to get forks on, and frame/swingarm/monoshock work done over the winter. In the process of working out what I want and who can do it for me. Will be selling off the IH front end, wheels and assorted parts. Just wanted an IH with a good engine, frame, swingarm, title etc.
Have got a 1 inch neck stem conversion for the 74 frame as that will be close to what was on the Suzuki. A local bike racing engineering/fabrication place will make the 2 fit together for me. After that will come the frame work. Rough plan is, like with my 76, keep the IH swingarm pivot and use that as the base for a new swingarm with monoshock mount.
Watch this space, but don't hold your breath - the 76 took 3 years and reckon this will be the same.
Paul
Le_Jack's Avatar
Le_Jack Le_Jack is offline
Sportster/Buell Model #2: XLS (Barn Find WIP)
Sportster/Buell Year #2: 1979
Other Motorcycle Model: XLH (basket case)
Other Motorcycle Year: 1976
Le_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of lightLe_Jack is a glorious beacon of light
Subscribed.... ;-)
chilly chilly is offline
chilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to all
Good luck with the project Paul, an interesting way to go, i look forward to your progress.
I Mono shocked a Norton Commando in 1994 which turned out to be a great bike, so it was two fingers up to the naysayers who said it couldn't be done.
Cheers
Chill
mct496's Avatar
mct496 mct496 is offline
Sportster/Buell Model #2: 84 xl paughco rigid
Other Motorcycle Model: 70 xlch
mct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to all
The Busch bros ( check out Busch&Busch blogspot for pics) put an aluminum mono shock yz 490 swing arm on an IH was almost a direct bolt on. They didn't use the mono shock on it though. Any pics of your mono shock bike?
yoshi's Avatar
yoshi yoshi is offline
Sportster/Buell Year: 1971
Sportster/Buell Model #2: FXRS-SP
Sportster/Buell Year #2: 1985
yoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud of
Pester power worked then Paul😉
Sounds worth me checking that out. Didn't take many pics of the monoshock Suzuki as I just wanted the forks, wheels and brakes from it. It was pretty ugly:
Couldn't use the monoshock from it as the bottom linkage took up too much space. Will use one that bolts straight to the swingarm, with frame mount somewhere around where the IH circuit breakers usually go.
Hopefully it will end up looking better than the Suzuki did
Originally Posted by yoshi View Post
Pester power worked then Paul��
Yep, finally a deal was struck for the IH, only took about a year, maybe more. Good things come to those who wait I guess.
Paul
Cheers
Chill
Any pics chilly? Would love to see that bike.
Paul
Proving a bit to much for me at the moment Paul , for some reason Photobucket have lost my pics and i can't copy and paste it from my desk top or e-mail pics ?
Graham Graham is offline
Sportster/Buell Year: 1982
Graham is a name known to allGraham is a name known to allGraham is a name known to allGraham is a name known to allGraham is a name known to allGraham is a name known to allGraham is a name known to allGraham is a name known to allGraham is a name known to allGraham is a name known to allGraham is a name known to all
Nice to hear you finally managed to get the guy to sell you that ironhead, looking forward to seeing how this project progresses!
West Texas Buffalo's Avatar
West Texas Buffalo West Texas Buffalo is offline
Sportster/Buell Year: 1970
Sportster/Buell Model #2: XLX61
Sportster/Buell Year #2: 1983
Other Motorcycle Model: Harley Softail
Other Motorcycle Year: 1984
West Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant futureWest Texas Buffalo has a brilliant future
Should have paid you for taking that GSX off their hands...can't stop laughing...
1970 XLCH, 1983 XLX61, 1984 FXST Ride...Wrench...Repeat
