0 tHE mONEY sHOT
0 1998 883 Front Brake Caliper
0 mileage
0 sprung solo seat and swing arm
Last Post: andy2175m4
0 Do you like Brazilians???
Last Post: Eric Von Zipper
0 Whats your carry gun?
0 ok to remove left footpeg stud?
Last Post: Les59
Last Post: maltesefalcon
0 Not sure what to do next
0 Xenas Hammer 1275 is alive
Last Post: xena
0 Another ticking/knocking thread- help
0 comfort poll?
Last Post: Joe_jeep
3 Wtb, Wts, Wtt, Wtg (EFIs)
0 Am I on the right track? Carb not getting fuel
Last Post: DirtyHarry68
3 Wtb, Wts, Wtt, Wtg (Rubber Mounts)
0 Will they fit.
Last Post: 93trident
0 Checking oil level with new suspension??
Last Post: Bikeaholic
0 2005 oil levels
11 Hardtail Struts (I searched but could find results)
Last Post: farmall
0 79 forward controls...why no products?
Last Post: farmall
0 Baffled Drag Pipe Slip Ons
Last Post: Sydney
NedNimrod, jduffy01, AlanT (73), jzink0883 (72), LVBOATDOC (69), glef (64), Dogsbd (59), wmbettsjr (45), darkcustom (44), jon8641 (37), powen8876 (32)
  #231
Old 8th November 2020
paulc paulc is offline
Sportster/Buell Year: 1976
Sportster/Buell Year #2: 74/5
paulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond repute
Originally Posted by Steve9 View Post
Love that exhaust!
Thanks Steve, it's a bit different for an IH, hopefully it will do the job ok
Originally Posted by needspeed View Post
4011P1 = Wiseco piston .010" oversize. Advertised as 10 to 1 compression. (but they are not.)
The bike looks great.
Thanks needspeed. That's good, don't particularly want 10:1 so happy if they're not that high, that's just what it came with.
Cam cover back on, pushrods in and alternator back on:
Next job will be adjust pushrods, install and set points then set static timing. After that I can move around to the primary and have a play with the hydraulic clutch before pulling the trans to swap the 4th gear and fit the splined shift lever shaft.
Paul
Old 11th November 2020
Thank you for sharing, gonna be a thing of beauty. Let the bonding continue!
I.B.A.#26543,
Old 15th November 2020
Thanks for that, it's definitely continuing. Bit more progress today:
Pushrods adjusted, points in and adjusted, static timing done.
Before pulling the trans I want to get my head around the hydraulic clutch and hopefully get it working. It's the design yoshi came up with, but with a slightly different slave cylinder as the one he used isn't available any longer. Details are on his thread about it.
I spent a while getting the slave cylinder fitted so that it is secure and doesn't block the path to putting in the primary cover bolt:
Fitted the longer rod that yoshi machined for me:
Bled the line through to see it working for the first time. It's a bit variable so far, probably still some air in the line and the primary cover is off, guess it will return better when the cover is on. Here's a quick view of what it does when I pull in the clutch lever:
https://youtu.be/NTPGvxLMmAQ
Next step will be to fit the primary, bleed the line through properly, adjust the clutch and see how it is then. Didn't have time to do that today as the sun came out so I took out the 76 for a ride.
Paul
Old 22nd November 2020
Had a play with the clutch today. Pulling on the lever seems to be doing what it should do:
https://youtu.be/bcFVnNlCPGs
Plates aren't moving though, whichever gear it's in pulling in the clutch lever doesn't allow it to roll free. This engine was put together over 4 years ago so the plates may well be stuck together, either that or I need to adjust to get more movement. Will pull the plates out and reinstall them next weekend then see how it is. Fine tuning can be done later but really want to get this hydraulic clutch working to some degree before I pull the trans, just so I know it works.
Paul
"This engine was put together over 4 years ago "
Clutch plates stuck for sure.
Start motor and warm up,
Get bike rolling and drop it into gear.
Shift into 2nd or 3rd.
Pull clutch lever in and rapidly open and close the throttle and the clutch will unstick.
Slip the clutch a little to "burn the fuzz off it".
Ride it like you stole it....
That makes a lot of sense ryder rick. I would like to get the clutch free before starting it for the first time though as I can't ride it until I get it reregistered It's registered properly in my name but the rules here mean I need to redo it (an inspection and a lot of paperwork, and a fair bit of time basically) after so much alteration and get a new plate. No riding till after that is done.
So I'll probably pull the plates, reinstall them then see if it will run if the clutch is working ok then. After getting it running I'll pull the trans to change to splined shift lever, remove and plug kickstart shaft and fit different 4th gear. If I can't get it running I'll sort the trans then try again. In theory it's ready to run now. After all this time I'm not in a rush.
Paul
Old 28th November 2020
Had a look at the clutch today. Took the plates out, checked they were all flat, cleaned them and put them back in. This clutch has a piece my 76 doesn't have - the black part you can see in this group of photos:
Not sure what that is Left it out for now. Clutch is working a little now but still a way to go before I get it right. In gear when I pull in the clutch it's easier to roll the bike but it's nowhere near yet how it should be. I'll play with that more after I've done what needs doing in the trans.
Big news of the day is that it runs now
Put some oil and fuel in it, checked I had spark then hit the button and it started. Did a couple of heat cycles then another short startup. Sounds very different to my 76. Either the pushrods need adjusting again or I can just hear them more because the exhaust is quieter. Worrying oil leak from somewhere which I'll look at in daylight, for now I'm just enjoying having it running at last. With the clutch how it is I haven't yet tried putting it in gear whilst running. Here's a pretty naff video, will do a better one soon but wanted to post something of it running:
https://www.youtube.com/watch?v=R0GdlTgPWq4
Beer time I think
Paul
billeuze's Avatar
billeuze billeuze is offline
Sportster/Buell Year: 80s
Other Motorcycle Year: 1983
billeuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond reputebilleuze has a reputation beyond repute
Congratulations Paul. It must feel great to start it up after a long term
Project like that.
Old 29th November 2020
The black guy is a balancer. Check Balance Masters?
Project like that.
Yes, very good indeed
Thanks ryder rick. Found a few discussions on them, they don't seem very highly thought of. I'll leave it off I think, at least for now.
Started it up again today, it runs ok at low revs, likes to cut out when I twist the throttle unless I do it very slowly. I got the clutch working for a while so rode the very very short length of my garage in first gear a few times Now it just dies when I try to let the clutch out, almost as if the rear brake is on. All I did was alter the lever settings a bit so not sure what changed but at least I know now I'm getting closer with it and have seen it work.
Not sure yet where the oil leak is coming from but it seems less that yesterday. Have got some towels underneath to try to figure it out. All of this stuff can wait until it's back together after doing the trans stuff - when I next get some time I'll start pulling things off to get to the trans.
Paul
