Last Post: joes95bobber
0 Cam question
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Last Post: dodgetrucken
Last Post: oldboy
0 Bike Beast
0 Old new guy
0 strange noise in top end
0 Oil leak
Last Post: Roane
Last Post: felis
0 BSA to be reborn...
Old 29th October 2016
Blowupster's Avatar
Blowupster Blowupster is offline
Sportster/Buell Model: Sporty XLH 883
Sportster/Buell Model #2: Sporty XLCH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: Duo-Glide 1964 FL
Other Motorcycle Year: 1964
Blowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud of
Default I recieved my new 1960 XLCH from New-Orleans
Well after more than 2 months my 1960 XLCH arrived in Geneva (Switzerland) 2 days ago.
Beautifull even if covered with rust...
Lot of parts are paint in black or chromed, but the rust was not correctly remove before.
The chain is full of dry rust. It’s the first time I can touch a chain that is completely dry.
You may imagine the result.
Ok I love my bike...
About the engine:
Hum , I turn gas and the S&S Super B leaks a lot...
Hum the magneto make no light in the plugs...
I will spend few days to clean the easy rust, and the Wonder about the magneto.
I open it and it seams to be like new inside. I remove the outside wire that is used to cut the engine. I pushed the sping and noticed that it's always 0.8 ohm (resistance) I wonder if this is normal ?
gpydeski gpydeski is offline
Sportster/Buell Year: 1970
gpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to behold
Default New 60
You can make that thing run like a Swiss watch.
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to behold
'pushed the spring...0.8ohms resistance'.
You will need to clarify what you are measuring across.
If you are measuring across the points, it will show a value when the coil is still part of the system.
S
Scott
'61 'CH
'60 'CH
I just noticed this is your first post. Congratulations on your new ride. You now own the very best there is.
There is a lot of maggy info in the Stickys on the top of the main IronHead thread page.
S
Old 30th October 2016
congradulations,Scott and i,both own 1960 XLCHs.where is the leak on the carb coming from?
Blowupster's Avatar
Thanks a lot for your welcome messages.
As I had not life answer from the engine, I remove the air filter to use Starter Spray inside of the S&S carb. So I noticed that gas was leaking inside of the carb as soon as I open the gas line.
Inside of the magneto there is a “breaker point kit. I measured 0.8ohm even if I pushed the spring. Yes of course the coil is connected. I heisted to dismantle all the wire first as the access may not be easy.
I read that S&S Super B and magneto is not the winner team to start engine in one stroke.
welcome to the wonderful world of Harley Davidson, by the time you finish, you will be a master mechanic. you will have a ton of help here but first, get organized. make a list on needs and tackle them one at a time. this will help in logic and keep the thread from bouncing around and perhaps confuse things. my first hd was older and I admit, it kick my butt and I take my hat off to those whose ride them. those era machines have beauty of their own but also come with idiosyncratic issues.
have fun!
if gas is running out of a,hole in the right side of the carb,likely the float is stuck down.when it rises up with the gas level it's supposed to shut off the flow of fuel.
Maggy stuff from the Stickys:
http://xlforum.net/forums/s....php?t=1391033
a great maggy post:
http://xlforum.net/forums/s...7&postcount=12
http://xlforum.net/forums/s....php?t=1343908
some light reading. find your way around the Stickys for more great reading.
s
Old 31st October 2016
Blowupster's Avatar
Thanks for welcome message, the explanation the fuel leaks and links for magneto.
Well I bought my 1992 Sportster in 1992 with 500miles second hand, and I still have it now. I already change everything that may break one day.
I had never problems with my CV carb and I change the ignition system for dual plugs per cylinder and dyna single fire with two coils.
But no experiment with magneto and S&S carbs for my “new” 1960 XLCH
Thanks for links that I will translate (in French) and print to be able to fellow the points close to the bike.
For the carb, perhaps I just need to open the down plate to remove dust that avoids stopping the fuel (?)
