0 Roadster - No Key Start
Last Post: exexpat93
0 Cam question
Last Post: T. Clark
Last Post: wongjohnson
0 tappet/blocks fitment by year
Last Post: commando57
0 my sunday driver...
Last Post: 84rzv500r
0 mainshaft rollers size
0 MS rollers way too tight
0 What engine oil do you use?
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Old 2nd November 2016
A check of ignition timing and pushrod/valve adjustment would also be in order.
How do stink bugs live with themselves?
Old 3rd November 2016
Blowupster's Avatar
Blowupster Blowupster is offline
Sportster/Buell Model: Sporty XLH 883
Sportster/Buell Model #2: Sporty XLCH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: Duo-Glide 1964 FL
Other Motorcycle Year: 1964
Blowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud of
Ok thanks. Tonight, I remove plugs and as expected they smell strong fuel. I kick 10 times to allow fuel ti escape easy. I cleaned the plugs and kick 10 times again then I put the spark plugs in.
Fuel line close, I kick 5 times and get nothing. I sprayed the air filter with “Fast starter spray” kick 2 times and got a “shot gun” answer with smoke escaping from air filter. Really loud. Ok I try again 4 times and the engine fire tree time very loud and smoke again from filter. I try again and get engine running short (perhaps 4 fires).
The drag pipes are so loud that I had to stop. It was late and don’t’ want my neighbour call the police.
Next time I have to find normal pipes that allow me to listen engine noise. I have some spare pipes for my 92 Sportster but brackets system are not same. Perhaps I have to try baffle kit for drag pipes but I suspect that they will not be efficient. What do you think?
BTW I’m surprised that my magneto twist only 5° ( a bracket that hold the S&S Super B avoid to move more).
Some pictures of my 1960 XLCH
snow snow is offline
Sportster/Buell Model: xlch sportster
Sportster/Buell Year: 1969
snow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant future
Man! That is a freakin awesome bike, Blowup! You cannot do any better than that. Stick with it--- there is nothing more rewarding than learning how to live with a magneto Sportster. I have a 69 XLCH and it took me two years to learn how to kick her properly--- then, she was a reliable one-kick machine! she had an S&S Super E. I've known guys that had "B" carbs, and they're tough starting with a CH. Once you learn your CH, you'll find that time spent with any other bike is wasted....
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to behold
That's a good looking machine!
S
Scott
'61 'CH
'60 'CH
Blowupster's Avatar
Well, here a close picture of the good looking machine.
Nothing that WD40 and an oil soak couldn't fix!
smokey 2 smokey 2 is offline
Sportster/Buell Model: 1970 XLCH
Sportster/Buell Year: 1970
Other Motorcycle Model: Ultra Classic
smokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of light
that looks like a great starter kit to me. Nothing that some time and money can't fix.
Oh, and some help from your friends in the forum.
WORK TO RIDE, RIDE TO WORK
How did you discover the bike, half way around the world?
Old 4th November 2016
Blowupster's Avatar
Well I already spent 1 hour on this rear wheel to clean….
Hum the cylinders were paint in black, now the paint escape to show rusty iron.
I bought it on Ebay this summer, one week before the Louisiana’s deluge. It travel to Miami on an open truck and just went on the boat a day before the peak of Hurricane Matthew. It probably stay weeks outside in warm salty rain before to be loaded in a warm and hermetic container to let 100% humidity finishing the job of rust for the 10 days needed to arrive to Le Havre in France.
If you compare to what happened to unlucky population, my rusty bike is peanuts problem. So sorry for them.
I was surprised when I opened the Magneto to discover that the inside was like new. The same when I inspected the cylinder (when I removed the sparks plugs).
New toys sometime annoy me, I prefer used ones. It happen that I lost time to find interesting item of this bike rider’s year. I already found a Swiss clock, German and Swedish cameras of 1960. My Jaguar is only 20 years old; not easy to find a alive Chevy Corvette C1 or a Aston-Martin DB4 for 20k$.
Old 7th November 2016
Blowupster's Avatar
Yesterday I was home during day time (Week-end) so I tried to start the loud monster. As the fuel leak is not resolved I have to cut fuel line and works with 1cc of fuel in the carb.
I kick 8 times with different position of Magneto and gas position and succeed to start the engine.
With this pity of fuel volume I succeed to check lights that works not so bad (The stop light is not correctly fixed and the front light is positioned to light the moon). Brake and the the 1st speed are ok(I have only a 50m long way in the garage. I expected the engine vibrations may help to resolve the fuel cut inside the carb.
That was not the case: Then I open fuel line and got a lot of fuel on the soil.
It’s urging to find normal pipes so I may check the engine anytime, I will remove the Super B carb to fix the fuel cut system.
I’m surprise how easy it is to kick this 883cc, with my 750 Triumph of 1979 it was a hell if I use normal shoes to kick.
BTW I had fun to ride it, the stroke is there and it seems perfect to use it daily as any modern Sportster.
Just care about braking on left side.
