Last Post: ericfreeman
Last Post: Rollbar
0 strange noise in top end
0 Cam question
0 Oil leak
Last Post: Roane
0 Old new guy
Last Post: BruceClarke9
Last Post: felis
0 Bike Beast
0 BSA to be reborn...
0 mainshaft rollers size
0 random rattle
0 Loses Power
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: iBloke
0 BEWARE Of SCAMMERS!
0 In search of XR1000 parts
Last Post: 84rzv500r
Last Post: LenC
0 84 rear wheel spacer confusion
Last Post: 83XLX
0 Swingarm Bearing ID?
Last Post: motorfish
0 windshield on a Custom
Last Post: Eric Von Zipper
  #601
Old 6 Days Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
The center stand lifts the rear wheel off the ground. How far depends on your wheel size and the shocks you have.
I am using one temporarily for my P3 Solo while it's being worked on.
It also depends on how soft the ground is.
They are NOT a great design. Getting the bike on and off is not a "ladies Job".
But it odes allow you to rotate the rear wheel.
If you have something like the work platform I use you can hook tie downs to the rear of the bike and hold the rear down while you work on the front forks.
Old 5 Days Ago
Blowupster's Avatar
Blowupster Blowupster is offline
Sportster/Buell Model: Sporty XLH 883
Sportster/Buell Model #2: Sporty XLCH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: Duo-Glide 1964 FL
Other Motorcycle Year: 1964
Blowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud ofBlowupster has much to be proud of
Thanks for answers. Great tank to ride more than 100km between gas stations ! perhaps I have to look for one for my next alp's tours.
Ok I ordered one and will see. This will help me for most of job. The picture show that the kit is realy on rear side.
Old 5 Days Ago
Blind Owl
I needed a large metal (aluminum) tank to hold enough Methanol for 7 laps at Phillip Island.
Can't use fiberglass (it de-laminates) and at WOT these engines drink a LOT of fuel.
A peanut tank would be lucky to get me through the warm up lap.
Old 5 Days Ago
Blowupster's Avatar
More Rocketster than Sportster !
Old 5 Days Ago
Rodzilla's Avatar
Rodzilla Rodzilla is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: Buell XB12S
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Too many to mention
Rodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really niceRodzilla is just really nice
That is a really nice looking tank. Who sells it??
Old 5 Days Ago
Blind Owl
That's actually a hand beaten tank based on a Norton Manx style tank.
I originally had it made to go on my sidecar but despite my discussions with the man, drawings showing dimensions and even a cardboard template, it was made wrong.
But one day I picked it up and to my astonishment it fits almost perfectly on the Sportster frame !
I might be able to do the full 3 laps at The Isle of Mann with this one ! (Every lap there is 37 miles !)
Old 5 Days Ago
Blind Owl
There are a number of people who make this style of tank. The guy I dealt with was in India. They make a lot of different tanks and can make just about anything you want.
Here's a sample.
https://www.ebay.com/itm/Cafe-Racer-...EAAOxyyq5TMuVF
There are guys in the USA as well, but check the price (and it's more if you want a custom tank)
And your problems stem from the fact that you need "wells" on the bottom of the tank to clear the Sportster heads.
If I was going to try to adopt one of these tanks to a Sportster frame I would just buy one from India (The USA made are no better) and take it to a local fabricator with the measurements I needed for the wells, and have him add then.
You are also going to work out how to mount these tanks. The original tanks sat on two frame rails and a flat bottom was no problem. It was held on by a strap running over the top of the tank from the neck to the seat area of the frame.
Old 5 Days Ago
Rodzilla's Avatar
Here's a sample.
Thanks! I have seen some similar to yours on some Norton race bikes, and a one or two street bikes. I should say, "I have seen pictures". I think I have only seen one in the flesh. I kind of know one of the India suppliers from the Barber Vintage Festival... They are always there, nice folks but as far as I know they only take orders at Barber..... the 10-15 tanks they bring are displays.
I really like the looks of an Ironhead with an aluminum tank......
Old 5 Days Ago
Blind Owl
Probably the best in America is (was ?) Even Wilcox. But not only did you need really deep pockets I was looking at a two year wait when I contacted him a few years ago.
