Last Post: joes95bobber
0 Cam question
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Last Post: dodgetrucken
Last Post: oldboy
0 Bike Beast
0 Old new guy
0 strange noise in top end
0 Oil leak
Last Post: Roane
Last Post: felis
0 BSA to be reborn...
Old 25th August 2019
blk80bike blk80bike is offline
blk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enough
Default Larger Roadster tank for 79-81 Sportster
I've been given more thought to swapping the 2.2 gallon tank on my 80 XLH, for something larger. I've been researching this on the forum and elsewhere but there isn't very much information for the 79-81, since the tanks were unique for these years.
Unfortunately most of the older posted photos here on the forum that showed those years are no longer available in the threads.
I'm leaning to use an original Roadster 3.5 tank with a 22mm petcock thread on the right side. I'm wondering if all the factory tanks all had the filler cap centered on the tank, or if depending on the year (79-81) were tanks also available offset to the right hand side of the tank? I'm finding a few used tanks over on fleabay, listed as a HD tank but some of these tanks may be aftermarket takeoffs and the sellers just don't know what they really have. Some are offset and some are not.
Another issue is the front/rear bolt mounting brackets for the 79-81 measure 15" on center but as I understand the Roadster tanks all attached to the frame (at the rear) with the spring, etc. I understand all that ... so if it has a rear mount like the 2.2 peanut tank it's not an original? Some of the tanks I'm seeing appear to either be 3.1 king tanks or Paughco tanks.
I like how the 79-81 Paughco tanks are offered with single or double caps which seem to be positioned really high to maximize fuel capacity and they use a 22mm petcock but they are offered in either a 3.0 gallon "Mustang" or big 4.2 "Axed" gallon tanks. I'm afraid a 4.2 tank is going to look to big.... all leading me back to considering an original Roadster 3.5 tank.
For those of you that have looked into this for your 79-81 is there some information that you can share?
1980 Sportster XLH 1000
Toejam503's Avatar
Air-cooled Forever
Sportster/Buell Year #2: 1981
A friend of mine has a '79 with a 3.1 gal. "King Tank" (flat bottom) that was painted to match and installed back in the mid '80's. His uncle (was original owner) purchased it thru Drag Specialties. They still sell the same tank, it's slightly taller and wider.
dieselvette's Avatar
I have an original 2004 roadster tank that of course won't bolt on yours, but could be adapted to fit. You can have it for the cost of S&H. There is a non-original petcock on it, IIRC does not need the vac port.
If you want measurements let ne know.
____________________________________________
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
If men can build it, men can fix it. - Tim Allen
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
TC88A ignition
0.030 head gasket, zero deck-height
Hammer 570 cams
Bronze oil pump gear, updated oil pump
30-tooth HDI belt sprocket (137-tooth belt)
I appreciate your generosity to offer me your tank. But I'm going to stick with more of a direct swap from my year. I'm trying to stick with using the 79-81 parts as much as possible. But thanks again.
Yeah I figured that, just thought I'd offer anyways. It's good that you're doing it right instead of a hack job.
FWIW I have an original (I think) front and rear fenders off a 1980 (roadster?) I intend to put the front on my 2004 depending if it fits the way I want it to. But if you know anyone who wants the rear (and maybe the front too) just lemme know.
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
What ever tank you select its up to you to make it fit. there`s no "easy button " on these sportsters
Old 26th August 2019
The 1979-82 3.6 gallon XLS fuel tank part numbers 60976-80 and 61215-83 is perfect for your 1979. It is very similar to the SuperGlide tank which is very good. Several of us on this forum have used these tanks.
ron521's Avatar
ron521 ron521 is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1991
ron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really nice
V-twin Mfg makes a 3.5 gallon tank which they call a replica K tank, it's available for several models. Here is the link to the one for 57-78...maybe there is one for the '79 also
http://www.vtwinmfg.com/webapp/wcs/s..._143733_143735
A great pleasure in life is doing what people say you cannot do.
Be sure to check out the SuperGlide tank and the mounting kit for it at J&P Cycles, etc. This tank and the Roadster tank do not depend on the positions of holes thru the top bar of the frame.
