0 Roadster - No Key Start
Last Post: exexpat93
0 Cam question
Last Post: T. Clark
Last Post: wongjohnson
0 tappet/blocks fitment by year
Last Post: commando57
0 my sunday driver...
Last Post: 84rzv500r
0 mainshaft rollers size
0 MS rollers way too tight
0 What engine oil do you use?
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Old 17th June 2020
rg500 rg500 is offline
Sportster/Buell Year: 1971
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1971
rg500 is a name known to allrg500 is a name known to allrg500 is a name known to allrg500 is a name known to allrg500 is a name known to allrg500 is a name known to allrg500 is a name known to allrg500 is a name known to allrg500 is a name known to allrg500 is a name known to allrg500 is a name known to all
The fender is a copy of the original, saddle on ebay from "mrmom9r" and the tank original that a friend has had lying on a shelf for many years.
Old 17th June 2020
Scott Scott is offline
Sportster/Buell Year: 1981
Other Motorcycle Year: 2002
Have you tried the twin carb setup yet? I’m guessing this is the same intake sold by cycle change (common intake instead of individual runners). I’ve strongly considered using them on my next IH but was afraid that might be two much carb filling one cylinder at a time.
Old 17th June 2020
Yes the intake is the same. No major problems so far, had to modify the gas roller so that the carburetor opened fully. The bike runs smoothly and nicely until you turn the throttle properly, then it pushes away really good.
Old 17th June 2020
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Instead of fitting 2 separate carbs, why not try a single 2 barrel carb like the vintage Mikuni Solex PHH 36. Two throats with their own jetting, very simple to adjust without the need to disassemble the carb. Only problem is they are no longer made and you have to hunt for them. Plus, you need a guy who knows them to do a rebuild so they work correctly. Otherwise, fantastic carbs (I have three of them!).
mikunisolex by Eric Freeman, on Flickr
P1000541 by Eric Freeman, on Flickr
Old 17th June 2020
Yes this is a bit of an experiment with this carburetor set, found these on a swap meet and I've seen these in older magazines and wanted to know if I can make these work the way I want. I'm a good way to reach that goal. Mikuni Solex PHH 36 looks interesting but not quite easy to find and I know that there are more modern carburetors that work great, but it's not as fun, and hopefully I learn something new.
Robyart Robyart is offline
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 84
Robyart is an unknown quantity at this point
Default Wow
Wow, always romanced the idea to acquire an xlcr but too pricey ! Love it in white!
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XLH 1200 S
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 83
Other Motorcycle Model: RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r is an unknown quantity at this point
Originally Posted by harley506d View Post
Stunning!
Agreed!!
1999 1200 Sport, SE 7500 ignition, SE air filter, DynoJet , Cone Engineering 2:1 pipe, Storz Steering damper, Russel Mach 3 Stainless Lines, VROD 4 piston front calipers, Bates Baja tires, XR1200 perf shocks/forks and triples coming soon...
1983 XR-1000S to XR-1000RRR....
waiteitei's Avatar
waiteitei waiteitei is offline
Sportster/Buell Model: XLH - Rowe Frame
waiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of light
stunning bike
Old 3 Days Ago
stratoblaster's Avatar
stratoblaster stratoblaster is offline
Sportster/Buell Model: xls
Sportster/Buell Year: 1979
stratoblaster is an unknown quantity at this point
Default xlcr replica
The Goose would be envious.
