0 Roadster - No Key Start
Last Post: exexpat93
0 Cam question
Last Post: T. Clark
Last Post: wongjohnson
0 tappet/blocks fitment by year
Last Post: commando57
0 my sunday driver...
Last Post: 84rzv500r
0 mainshaft rollers size
0 MS rollers way too tight
0 What engine oil do you use?
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Old 3 Weeks Ago
on the side stand at idle..that could be in the trans.mine jumped into gear one time while idling on the side stand.just once so far.
Old 3 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Check your chain guard too.
Maybe all of your tinware.
Is it possibly coming from near the generator area ?
Old 3 Weeks Ago
sportsterdoc's Avatar
Originally Posted by RicThompson View Post
Unfortunately this random rattle can occur with the bike sitting on the side stand in the garage. It's even made the noise as the engine is shutting down.
All exhaust clamps snug?
Old 3 Weeks Ago
rejeanprimeau's Avatar
1969 bike and only one intermittent rattle, if it bug you that much you can give me that rattler and I'll enjoy it with a mile wide grin.
Old 3 Weeks Ago
Sportster/Buell Year: 1969
RicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud of
So far I've already looked into the previous suggestions except the transmission. It shifts like it should and doesn't pop out of gear. The oil drained from trans/primary was clean and void of any particles. rejeanprimeau I guarantee if you were to ride it you would have way more than a smile.
Old 3 Weeks Ago
randy3934's Avatar
I was just chasing a rattle on my 77 xlh, intermittent also, well finally found it, damn rear fender is cracked behind the oil bag, put a couple layers of duct tape over it and rattle was gone hahahah I'll weld it up and repaint this winter along with a bunch of other maintenance she needs.
Old 3 Weeks Ago
Originally Posted by randy3934 View Post
I was just chasing a rattle on my 77 xlh...
You should inspect how that rear fender is installed as the correct technique is often missed.
You need the bracket and the buffer...
59795-52A rear fender front bracket with buffer
59798-52 rear fender rubber buffer
The fender is mounted only with the top bolts - no bolts are used in the two big holes at the bottom-front of the rear fender.
Old 3 Weeks Ago
randy3934's Avatar
10 years ago when I built the bike I painted the rear fender, you are right, those parts are not there.
Old 3 Weeks Ago
11B40 11B40 is offline
In a worst case scenario, It could be the rollers going away. They will be silent for a while and then start tinking as a roller is destroyed, then more quiet, then more tinking. You should see sparklers in the engine oil not primary.
Old 3 Weeks Ago
cazz1000 cazz1000 is offline
Sportster/Buell Model: xlx
dam ,,that sux,s,,,humm..i might have a bit of that going on
