Last Post: ericfreeman
Last Post: Rollbar
0 strange noise in top end
0 Cam question
0 Oil leak
Last Post: Roane
0 Old new guy
Last Post: BruceClarke9
Last Post: felis
0 Bike Beast
0 BSA to be reborn...
0 mainshaft rollers size
0 random rattle
0 Loses Power
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: iBloke
0 BEWARE Of SCAMMERS!
0 In search of XR1000 parts
Last Post: 84rzv500r
Last Post: LenC
0 84 rear wheel spacer confusion
Last Post: 83XLX
0 Swingarm Bearing ID?
Last Post: motorfish
0 windshield on a Custom
Last Post: Eric Von Zipper
  #51
Old 2 Days Ago
wedge's Avatar
wedge wedge is offline
Well, there is the answer, if you are deaf in one eye, then you develop the ability to see better out of the other ear. El Simplemente!
Old 2 Days Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
It has occurred to me that if I do lose the hearing in my other ear I will be deaf dumb and blind.
Old 8 Hours Ago
Sportster/Buell Year: 1969
RicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud of
So I pulled the mag removed the old coil cleaned the cavity installed the new coil. Removed the old condenser, installed the new one, same with the spark plugs. Reinstalled the magneto, set the timing. Fired right up. Now back to chasing noise.
Old 7 Hours Ago
out of those 3 or 4 changes which one do you think gave you spark again?
Old 7 Hours Ago
The magneto has been functioning on a wing and a prayer till the other day. I had only put points and a condenser in it and worked for awhile. When I pulled the coil out there was sand and bugs in the cavity. The rotor is rusted. Magnetism is strong. The old coil had numerous cracks from age. Spring to spring ohms was 0. Pretty sure coil was done.
Old 5 Hours Ago
copy that.
