0 Roadster - No Key Start
Last Post: Andy56
0 Cam question
Last Post: T. Clark
Last Post: wongjohnson
0 tappet/blocks fitment by year
Last Post: commando57
0 my sunday driver...
Last Post: 84rzv500r
0 mainshaft rollers size
0 MS rollers way too tight
0 What engine oil do you use?
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
blk80bike blk80bike is offline
blk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enough
I ended up putting a fresh gasket on it. I was surprised how much crud accumulated under the inner cover. Much of which was from rust forming on the 2 screws securing the inner cover. For now I just put some blue loctite on the button head screws and called it a day. If they seem to work their way loose I'll just tap them for a size up.
1980 Sportster XLH 1000
Old 6 Days Ago
mikethebike61's Avatar
And replace them with brass
Old 6 Days Ago
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
All I can do is state what I fixed on my 1990.
Harly points stand off bolts are 8-32 thread/
When my posts broke off in da case
I drilled out case to 5/16 coarse thread. Tapped the holes. Made up my own heli-coil out of a old 5/16 bolt. Tapped the center of 5/16 bolt for 8-32 screw. Ground a slot for screw driver to drive in heli coil.
Blue Loctite. Top of plate post is also tapped out for 8-32 screws.
Traveled to
Old 5 Days Ago
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: Cyclone
Other Motorcycle Model: FXDC
I like that "italian helicoil" Rok.
Those heli insertion tools are expensive!
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertrap 2/2
