0 Roadster - No Key Start
Last Post: exexpat93
0 Cam question
Last Post: T. Clark
Last Post: wongjohnson
0 tappet/blocks fitment by year
Last Post: commando57
0 my sunday driver...
Last Post: 84rzv500r
0 mainshaft rollers size
0 MS rollers way too tight
0 What engine oil do you use?
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
sportsterdoc's Avatar
Originally Posted by ferretface View Post
Now I'm even more confused...Summit Racing stocks the Yuasa YTX20H-BS but has this to say...
"Battery is sold dry. Customer must fill battery with included acid and charge before battery can be used."
Yes, the AGM info on Sportsterpedia needs updating.
There are customer fill AGMs, which cannot be vacuum filled.
Once filled and sealed, they should be the same/close to same as non-vacuum filled AGM
Some folks prefer to fill their own, thinking fresher...but as many AGMs that I have bought in the last few years for many different vehicles, the mfg date has not been over a month old.
See post 13 in this thread
http://xlforum.net/forums/showthread...ed#post5785430
ferretface's Avatar
BTW: My charging system is the Powerraythor 65 alternator conversion as sold by saddlebagrail here on the forum...
In searching for the voltage range on that system I only found the thread when you were installing. What is maximum voltage at higher RPMs?
ferretface's Avatar
Ray sends instructions with the unit; I installed it last year. I'll have to root around and find them...I have about three 3-ring binders full of threads, pics, and .PDF docs on stuff I was interested in...In no particular order...
Ah - 14.8 volts just above idle. I'm reading Ray's instruction sheet for that. My on-the-bike readings averaged 14.43-14.44v at 1500-3000rpm. The integral regulator kicks in after that.
ferretface's Avatar
I received two emails from my inquiries about filling/sealed YTX20H-BS batteries (or their clones)...Summit sells them unsealed but supplies the acid; Battery Mart sells them filled & factory sealed. Drag Specialties seems to have the factory sealed also.
mikethebike61's Avatar
Odyssey AGM
FULL MILSPEC
Brass terminals
Should be fine.
My truck, Jeep other vehicles are typical 13.8-14.8 vdc and AGMs do better than average at 2 1/2 years or so, in hot desert climate (pushing 120 F). Whereas lead-acid are only about 2 years.
For my 1994, I've used the Extreme Magna Power AGM battery (made by East Penn - EXT16 - 325CCA - 19Ah - 17lbs - Tight fit) since early 2013. It comes factory activated. https://www.pepboys.com/magna-power-...roduct/1055140
The first one died after 4-years - the second is now showing signs of dying at 4-years...
I bought mine thru Pep Boys (the lowest price, especially with an online ordering discount)... Current price is $88.99 - 20% discount = about $72.
Be sure you check which size version you need & the terminal locations...
Sportster/Buell Model: XLH 883/1250
Sportster/Buell Year: 1991
We just got an AGM battery for my buddy's dual sport. It came dry, with acid. The "plugs" for the fill holes was one continuous strip with plugs, and flat on top. So, when filled and plug strip installed, there was no way to remove the strip. Perhaps that's what the confusion is about?
John
randy3934's Avatar
I have a 5 year old deka in one of my shovelheads, still good hot battery.
