0 Roadster - No Key Start
Last Post: exexpat93
0 Cam question
Last Post: T. Clark
Last Post: wongjohnson
0 tappet/blocks fitment by year
Last Post: commando57
0 my sunday driver...
Last Post: 84rzv500r
0 mainshaft rollers size
0 MS rollers way too tight
0 What engine oil do you use?
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
  #51
Old 3 Days Ago
Yellowstone Kelly's Avatar
Ironhead Rider
Sportster/Buell Year: 1982
Sportster/Buell Year #2: 1969
Other Motorcycle Model: FLSTC
Other Motorcycle Year: 1996
Yellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant future
Originally Posted by mastiffhound View Post
I also broke down & picked up a Battery Tender, my Dyna already had the pigtail attached so I figured I might as well. The thing that always worried me was forgetting to unplug it before starting my bike & just taking off
I had the same thought about forgetting to unplug it, so I set a small wood box on my bike seat and set the Battery Tender in the box when I hook it up.
I could easily not see the black charger cable hanging down off the side of my black blike, but there's not much chance of not seeing the wood box sitting on the seat.
"Never underestimate the power of human stupidity." Robert A. Heinlein
Old 3 Days Ago
rellquist rellquist is offline
Sportster/Buell Model: Hugger
Sportster/Buell Year: 1989
rellquist is an unknown quantity at this point
I had a Scorpion AGM in my Yamaha for 6 years and it worked great. I bought one for my Sportster and it was dead in a year an a half. It always tested good but wouldn't start the bike. I kept a battery tender on it all the time and the charging system on the bike works fine. I just bought a Yuasa and it seems to work well. I have used their Lead Acid before and they worked well. I hope the AGM type do a s good a job.
Old 3 Days Ago
mastiffhound's Avatar
mastiffhound mastiffhound is offline
Sportster/Buell Year: N/A
Sportster/Buell Model #2: N/A
Other Motorcycle Model: FXDF Fat Bob
mastiffhound is on a distinguished roadmastiffhound is on a distinguished roadmastiffhound is on a distinguished road
I'd forgot about watching this on batteries months ago, it was by FortNine.
I seem to remember after all things considered (initial price, trickle charger price, safety, weight, service life, etc.) I came away thinking the winners were Gel & AGM.
The Gel was slightly heavier though, as I think it's just an AGM with silica sprinkled in to gelatinize the acid.
https://www.youtube.com/watch?v=3ywopGAXP-I
Old 3 Days Ago
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
I have a gel in my old Honda that doesn’t get ridden very much, and an AGM in my Ironhead. The reason I put a gel in the Honda is that gel batteries respond well to charging when they’re discharged quite a bit from unuse. AGM batteries don’t last as long if you let them get close to dead and recharge them.
Old 2 Days Ago
Andy56 Andy56 is offline
Andy56 is a splendid one to beholdAndy56 is a splendid one to beholdAndy56 is a splendid one to beholdAndy56 is a splendid one to beholdAndy56 is a splendid one to beholdAndy56 is a splendid one to beholdAndy56 is a splendid one to beholdAndy56 is a splendid one to beholdAndy56 is a splendid one to beholdAndy56 is a splendid one to beholdAndy56 is a splendid one to behold
Now I'm even more confused...Summit Racing stocks the Yuasa YTX20H-BS but has this to say...
"Battery is sold dry. Customer must fill battery with included acid and charge before battery can be used."
They go on to say in Item Description - "They are permanently sealed, never need refilling, and are ideal for motorcycles..."
It is not unusual to have a dry charge lead acid battery that you fill with acid.
Once filled and the seal is pressed into place it will be a sealed non-maintenance battery.
ETA: Oops I just replied to a post from page 1.
If you take a look at some chargers you will see they have a cold weather setting. Apparently AGM needs a slightly higher voltage when it is cold.
