0 MS rollers way too tight
0 82 XLH struggling for power
0 -65A mufflers
Last Post: a-sad-anorak
Last Post: leon bee
Last Post: murphdog
0 Tools
0 Zippers 1250 kit
Last Post: wardie
0 my daily driver
Last Post: 84rzv500r
0 Newbie
Last Post: BitterOldMan
0 OEM Headlight Bucket?
Last Post: spoon
0 KBS tank sealer
Last Post: mrmom9r
0 100 vs 110 front tire
0 mainshaft rollers size
Last Post: PappaBravo
Last Post: jcro61
0 my sunday driver...
0 Now running 3.40 factory gearing
0 carbs?
CaptainZoop CaptainZoop is offline
Sportster/Buell Model: xl1000
Sportster/Buell Year: 1982
CaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of lightCaptainZoop is a glorious beacon of light
Default Top end rebuild, what size rings to get?
Hey guys, I'm tearing in to the top end of my 77 sportster to hopefully resolve some overheating issues. I picked the bike up from a guy who said it sat for 10+ years, and I've already gone through the whole thing and got it running smooth. The only problem now is the rear cylinder overheating. (The rear cylinder runs at 400+ degrees and smokes while the front only runs at 200+). Worn rings and carbon build up were my guess.
I have the heads apart and will be honing the cylinders and removing the carbon deposits from the pistons, combustion chamber, and valves as well as lapping the valves if needed.
My only question so far is what size rings should I be getting if I am going to be honing the cylinders? The stamp on the top of the piston says "030", so I have to assume that means ".030", right? (My first time honing).
Any advise is appreciated. Thanks
if the rings are worn the cylinders may be too.the only way to know is to have them measured,pistons also.measurements need to be taken in several places.
doodah man's Avatar
If you are only honing, then I feel like you will want the same size rings to put back in. You will still want to check the ring end gap, and make sure to clean the fire ring - both heads and cylinders.
kitabel kitabel is offline
Sportster/Buell Year: 1989
The next smallest ring oversize is frequently recommended, which will (probably) give negative end gap (the gap is proportionate to the size × Π (.040" is .031" tighter than .030") and require grinding back the ring ends to meet your specs. The factory says ".010-.020" but IMHO .004" per inch of bore is preferred, .013" or slightly more (.010" is dangerous).
Unfortunately, this also increases the radial tension on the ring and may cause elevated wear.
Okay, duely noted. I think I will go with a new set of rings that are the same size. The cylinders don't look that bad but I will find out how to measure them before reassembling. Thanks guys
if you do custom cut end gaps, there is a correct way so research. i always custom cut. as far as radial tension goes, not much to worry about.
your biggest issue will be taper and i believe hd limit is .006. excessive taper leads to ring fatique.
That and the ridge at the top of the cylinder catching on the new ring....
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1991 Honda XR600
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant future
Default m
This is only my suggestion, do you have the cylinders off the bike and in your hand? If so, take them to your local machine shop along with the pistons and get them measured properly now for out of round, taper and piston clearance, they will either be in tolerance or they won’t. If you have taken the time to strip it this far and then build it back up with new gaskets etc it’s better to do it right while you’re there. Have a good look at the valve seats, guides and stem protrusion too. If you have gotten this far stripping down to this level without any help then you are probably quite a capable mechanic. This is a great forum with plenty of helpful advice from guys who have been down this road numerous times. There may be other issues causing heat in the rear or even the lack of in the front.
........Davi.
Wobbly points cam?
install valve seats. unleaded fuel leads to recession.
