0 Cam question
Last Post: T. Clark
Last Post: ericfreeman
Last Post: Rollbar
0 strange noise in top end
0 Oil leak
Last Post: Roane
0 Old new guy
Last Post: BruceClarke9
Last Post: felis
0 Bike Beast
0 BSA to be reborn...
0 mainshaft rollers size
0 random rattle
0 Loses Power
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: iBloke
0 BEWARE Of SCAMMERS!
0 In search of XR1000 parts
Last Post: 84rzv500r
Last Post: LenC
0 84 rear wheel spacer confusion
Last Post: 83XLX
0 Swingarm Bearing ID?
Last Post: motorfish
0 windshield on a Custom
Last Post: Eric Von Zipper
Gold Member's Avatar
Sportster/Buell Year: 1972
Default trans spacer question
Shouldn't there be a spacer/washer between gear #38 and the door?
Stop by my build thread:
In this case the parts book is not wrong.
Old 6 Days Ago
So there's no spacer there? My gear is shiny from rubbing up against something.
Old 6 Days Ago
The trap door.
Old 6 Days Ago
Yes I know but spinning steel up against aluminum without a washer? Okay but it doesn't make sense to me.
Old 6 Days Ago
I've always wondered why Harley did it that way too. Seems it would be better to have a hardened steel thrust washer there. (they use one on the other side of the countershaft) But consider this:
An aluminum piston lives for thousands of miles in a cast iron cylinder at very high heat, high speed with alot of thrust applied to the skirt. Made posible by an oil film.
Steel tappets that have a lot of side thrust go up and down in aluminum guides.
Steel oil pump gears turn in an aluminum pump body.
In a perfect world there is no side thrust with spur gears on parallel shafts, so a steel gear should be able to run against the aluminum door with an oil film.
However I have seen trans doors that the gear has worn into, but that is usually because something else is worn or set wrong.
The C shaft drive gear has a raised circular ring on one side and that goes against the door. In a way, that acts as a spacer, keeping most of the gear from touching the door.
